sonofsam
2 Permanent Lives Inside Car
sonofsam
Hi People,seems i have two wires on my 406(no keypad) loom that require a constant live inside the 205
Can i take a feed from cigarette lighter for one and starter motor(wire 46) for the other
Thanks Hilgie for confirmation on other wires
Just these two left to sort :D
Sam.
Cig lighter should be fine imo but the starter wire is a switched feed via the ignition barrel afaik. It only goes to the solenoid.
sonofsam
Ok cheers Graham,i shall disregard the starter wire.
Is there a constant live to ignition barrel,would this be better to use?
M@tt
i'm sure there are 2 permanent lives going to the barrel, a red one and a whitish one as well both fairly thick, numbers escape me for the moment (wiring diagram doesn't give numbers unfortunately).
i believe one is the power for when the key is at A & M and the other is when it is cranking
HTH
There is another permanent live going to the back of the stereo to keep the memory stored.
Would that be of any use?
stevec205gti
Why do you need to take them from two points? If they both require a permanent feed then you can just connect them to one point
sonofsam
Well i have two wires that need constant live and was unsure if it was ok
to connect 2 into 1 ,guess it must be :ph34r:
The two wires in question are atleast 50amp and 5-6mm thick and i think supply loom and ECU with power.
So the ignition live input should be upto the job.
Thanks people.
stevec205gti
Well - if they're that big I wouldn't connect them to one source B)
If these are seriously beefy cables you might be better off running your own permanent fused feed from the battery - that way you can make sure you don't over cook anything
les3002
connect them to the old ecus live feed.
M@tt
i would have thought any of the feeds inside the car should be ok, can't see why the ecu would need such heavy duty wiring
sonofsam
not even sure if it is for ecu TBH :unsure:
I'll get to the bottom of this,dont worry Gents
