hengti
Engine Mount
hengti
Looking to replace the right hand engine mount at some point
Believe it's somewhere near the battery tray - ?
Couple of quick questions -
is it any easy job?
if I go for an uprated (grp n?) mount, will the car vibrate much more than with a std one?
Henry
e30m3
Very easy job. just remove the battery, I'd put a jack under the gearbox to stop it droping and then you've got 2 13mm nuts and a larger nut (could be 16mm) and it comes straight off.
I've not trid the Gpn N mounts but hopefully will be soon. I'd go for them over the standard ones
j_turnell
The large nut is 18mm, and it shouldnt vibrate too much with just the group n gearbox mount but if you do the bottom one especially you will notice vibrations but they will settle over time.
madmoog
Sorry to hijack slightly, but on a similar note how easy is it to do the top engine mount?
Simes
cough* search!
