ajones12 0 Posted February 28, 2006 After reifitting my gearbox after a clutch change I need to fill it back up with oil. Thing is a) where does it go and from the Haynes manual it seems like the oil is the same for gearbox and engine - is this right. My car is a 'H' plate 1.9GTi in standard fettle - is this a BE3 or BH3 gearbox? Share this post Link to post Share on other sites
kate205gti 4 Posted February 28, 2006 (edited) undo the 19mm bolt on the gearbox under the passenger wheel arch, keep the car level and you should be able to fit 2litres in if it was totally drained, or just fill it till it comes back out edit: oil is definately not the same - you'll need 75/80 gearbox oil or similar from halfords or any motor factors - gearbox oil smells like dead dogs, engine oil doesnt box is a BE3 (reverse under 5th) Edited February 28, 2006 by kate205gti Share this post Link to post Share on other sites
ajones12 0 Posted February 28, 2006 Cheers Kate - can you fill the car up whilst on its wheels, i.e. level or do I need to jack it up? Share this post Link to post Share on other sites
C_W 3 1 Cars Posted February 28, 2006 - gearbox oil smells like dead dogs, engine oil doesnt (Normally it's used gearbox oil that smells bad isn't it? new oil tends to smell normal to me) Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted February 28, 2006 A H reg GTi should have a BE3, like kate said. The BH gearbox is fitted to the lower spec 205's than the GTi. There is a breather on the top of the gearbox in the engine bay that I remove to fill the gearbox with two litres of oil, that way it can be done on the wheels & you don't need to jack it to work in the passenger wheel arch. If you have the standard intake system you need to remove quite a bit of it so jackingthe car to get into the wheel arch is easier. Jack the car, remove the wheel & then lower it slightly so the car is sat level & fill it through the fill/level hole. It takes a while this way & can be messy. Graham. Share this post Link to post Share on other sites
Redtop 14 2 Cars Posted February 28, 2006 Also don't loose the wee plastic breather ontop of the nut. It comes out easily and can be miss placed easily Share this post Link to post Share on other sites
hengti 2 Posted February 28, 2006 (Normally it's used gearbox oil that smells bad isn't it? new oil tends to smell normal to me) love the smell of fresh gear oil - reminds me of machine shops almost as good as the smell of a burnt Castrol R! Share this post Link to post Share on other sites
ajones12 0 Posted March 1, 2006 Cheers Graham - thanks for the advice. Share this post Link to post Share on other sites
Simmy 0 Posted March 4, 2006 I find graham (pugtorque)'s method much easier (especially with a K&N), though in this case the onus is on you to put in only 2litres, filling from the side as kate said means you physically can't put too much oil in. Share this post Link to post Share on other sites
pacey205 2 Posted March 4, 2006 (edited) I fill it from the side point and use an old 1litre garbox oil container and a length of pipe that fits into the bolt hole as a header type system which works really well, also means you dont need to jack the car up just get in behind the wheel to remove the bolt. I normally prop the filler bottle up by the header tank/battery where you can balance it. Michael Edited March 4, 2006 by pacey205 Share this post Link to post Share on other sites
Jonmurgie 2 Posted March 4, 2006 This guide on swapping a gearbox shows where/how to fill the gearbox: http://www.mdracing.co.uk/howto4.asp Share this post Link to post Share on other sites
kyepan 291 Posted March 8, 2006 i've got loads of 75w80 spare in the garage, would this be a suitable replacement oil, or cause problems? Share this post Link to post Share on other sites
kate205gti 4 Posted March 8, 2006 thats fine as long as its not too old Share this post Link to post Share on other sites
kyepan 291 Posted March 8, 2006 thats fine as long as its not too old its a few years old, maybe 4... but its never been opened. unipart stuff. ta Justin. Share this post Link to post Share on other sites
