mi16nut 0 Posted February 27, 2006 I've finally succumbed to a set of 307 HDi discs & calipers and need advice on pads & master cylinder. A search produced loads of threads, but seemingly no definitive answers although I do understand that it may be down to personal preference. What are peoples views on whether the mc needs changing & if so, to what? 306 XSi or 405 Mi16 4x4 at 22.2mm seem to be suggested, whereas the 406 at 23.8mm is generally for GTi6 calipers. Can anyone confirm the caliper piston sizes on standard 1.9 girlings & the 307's? Secondly, I currently have Mintex 1144's on ATE powerdiscs. They work well, but list price for the 307 calipers is £100! Will standard pads be up to fast road & 5/6 trackdays per year, or should I stump a ton for the 1144's? Cheers, Mark. Share this post Link to post Share on other sites
chownr 0 Posted February 28, 2006 When I first changed over to 307 brakes from standard 1.6 calipers and discs with Mintex 1144s I used the standard 1.9 m/c with no real problems but the travel on the pedal was slightly more than I wanted - nothing excessive but I like a brake pedal with almost no travel at all. Ive ended up using the 406 cyclinder which is fine. As for pads I used standard at first with no real problems but after several road rallies they did go off a little and didnt seem to stop at all. I didnt see the point in spending £100 on 1144s so Ive had greenstuff on for about half a season now without any problems at all and only occasional squeel. Just my opinion Im sure others will have some too. Rich Share this post Link to post Share on other sites
Bonzai 2 Posted February 28, 2006 im using standard rated discs and pads, and the original 1.9 mc its fine for me on road use, next week will be the testing point when i do a full day at llandow. Share this post Link to post Share on other sites
tom_m 0 Posted February 28, 2006 i'm using standard 307 discs with custom grooves machined into them and standard pads with the standard 1.9 mc and braided hoses, as Bonsai its fine for me on fast road use. there is a slighty longer pedal than on stock set-up, but after using the 23mm mc i'm happy, because there was 0 modulation with it and personally i hated it. i am tempted to try the 22mm mc just to see what its like, but its not high on my list of prioites Share this post Link to post Share on other sites
jim205GTI 3 Posted February 28, 2006 i've never found a problem with using the standard m/c but mine has only been used on the road they do look good under the speedlines though minimal clearance but ......... Share this post Link to post Share on other sites
mi16nut 0 Posted March 1, 2006 (edited) Cheers for the replies. Pagid & Ferodo don't appear to do 307/ 206GTi 180 fitments yet. EBC Greenstuff can be got for @ £50 & Chownr reports no problems, so I may try those. Anyone using a 22mm mastercylinder? If so, from what; 306 or 405? Edited March 1, 2006 by mi16nut Share this post Link to post Share on other sites
tom_m 0 Posted March 1, 2006 personally mate i don't rate green stuff over standard, tho they do produce WAY less dust than stock compunds so i might give them a go next time i need pads, but only to stop cleaning the wheels every two days! Share this post Link to post Share on other sites
Bonzai 2 Posted March 4, 2006 just have to say the brakes were amazing on the trackday i did today, although i only managed 7 or 8 laps before quiting Share this post Link to post Share on other sites
Simes 248 2 Cars Posted May 19, 2006 Just thought I'd bring this up again, With 307HDI calipers what M/C's are you using. I'm going to replace my M/C regardless but I quite fancy a firmer pedal feel. answers please! Share this post Link to post Share on other sites
rescue dude 0 Posted May 19, 2006 I'm gonna keep an eye on this thread cos i'm currently sourcing some 307 calipers for my 1.9. I like a firm brake pedal so not sure if i'll like the feel with the standard 1.9 master cylinder but i'll give it a go for a bit. Don't let me interrupt you carry on. Share this post Link to post Share on other sites
rescue dude 0 Posted May 24, 2006 Just a thought. I've fitted 309 shaft's and wishbones. Will the 307 calipers and discs fit or are the hubs different sizes? Share this post Link to post Share on other sites
TEKNOPUG 3 Posted May 24, 2006 I need to get a new MC so I might try and source the 22mm from a 405. Also, the resevoir from the 405/406/306 (can't remember which) is a much better design and will allow the use of an eezi-bleed (1.9 resevoirs never seal properly from my experience). Share this post Link to post Share on other sites
Craigb 2 Posted May 24, 2006 Just a thought. I've fitted 309 shaft's and wishbones. Will the 307 calipers and discs fit or are the hubs different sizes? Yes they will fit , that what i had on mine before i took the 309 stuff off and put the 205 shafts back in .. p.s. Long OS 309 shaft for sale or swap for good 205 shaft Share this post Link to post Share on other sites
TEKNOPUG 3 Posted May 24, 2006 The only 22.2mm 405 MC I can find is for an ABS model, which isn't really what I'm after unfortunately Share this post Link to post Share on other sites
rescue dude 0 Posted May 24, 2006 Thanks Craig, Was sure they would but wanted to check before parting with the wonga. Share this post Link to post Share on other sites
Simes 248 2 Cars Posted May 24, 2006 Any more hints on a m/c? I'm going to leave my current one in place over the brake swap and see how that goes....it will need replacing though. Miles did mention to me about 306 M/c and resevoir - but I've forgotten that conversation. Share this post Link to post Share on other sites
Guest rick03054 Posted May 24, 2006 (edited) I got a 22.2mm one for a pre '97 306 2.0l convertible, (part number 4601.CO) and I just used the 205 reservoir. I think it's listed as an ABS model but has 4 ports and works fine. Edited May 24, 2006 by rick03054 Share this post Link to post Share on other sites
dead205 0 Posted May 24, 2006 I fitted the 307 set last week with standard discs and pads. So far i've been very impressed, but I plan to fit the 4 port 23mm master cylinder from the 406 (cheers Danpug). I think master cylinder choice with this setup is just a matter of what your used to, there isn't too much travel by any means and it certainly isn't dangerous in any way but i'm used to there being very little movement before braking kicks in. If you fit this set up and take time to get used to it there could be an upside to the longer pedel travel in that if it's an everyday car it is easier to judge when only light braking is needed - less brakes on or off syndrome. mark Share this post Link to post Share on other sites
