jim205GTI 3 Posted February 23, 2006 Well i have managed to get hold of a loom and an ecu ....it a three 3 row type and if i remember right these use the knock sensor? On the mi block i am not sure if i have the sensor or not. Could someone post a pic up of one so i know what to look for! If i don't have is it still possible to run it with out even with that ecu? cheers Jim Share this post Link to post Share on other sites
petert 601 Posted February 24, 2006 If you run without a knock sensor the timing will be seriously retarded, enough to only make 65kW at the wheels. A double ended stud replaces the M8 bolt that secures the #3 mains cap. Share this post Link to post Share on other sites
