matt205xs 0 Posted February 22, 2006 hi i have rcently bought a 205 s16 and was on carbs so no inlets injectors etc so i need to re install this which will be no problem. only thing which im confused about is what ecu to use, as i think the 306 s16 has a digital keypad immobilser so im presuming the ecu will be locked?? so can i use a 2.0 16v mi ecu with the 8v loom? or can i use a 205 gti's ecu? thanks Share this post Link to post Share on other sites
petert 601 Posted February 22, 2006 I'd look for a Motronic 1.3 ECU and 1.9L Mi16 inlet. Share this post Link to post Share on other sites
matt205xs 0 Posted February 22, 2006 im wanting to keep the standard inlet on at the mo to get it running, wil that ecu work for the 2.0 16v block? Share this post Link to post Share on other sites
RHULPUG 0 Posted February 24, 2006 I'm running an Omex fully mappable ecu on my 205 S16 I'm running an Omex fully mappable ecu on my 205 S16 Share this post Link to post Share on other sites
Bonzai 2 Posted March 18, 2006 do you need an s16 inlet? i have one complete with t/b, injectors etc and its got all of the loom ends so you can work out what goes where Share this post Link to post Share on other sites
