PhilCTI
Rolling Road
PhilCTI
Hopefully I will get the car on the road in the next couple of weeks,
can someone suggest a rolling road in the Hampshire area where I can get it tuned properly?
I bought the car as a sorn, so I don't know how well it's set up, I've also fitting an induction kit, mainly because the original air box was falling off and I got fed up with all the pipes in the way.
I did tweak the brass screw on the inlet slightly to get the engine to keep running on idle, and it does run sweetly now, well for a 205! but it needs to be done properly, as someone's bound to say it will blow up now because I've touched it!
many thanks,
Phil
You don;t need a rolling road to set it up really, Any good tuner can do this by using a CO analizer in the exhaust pipe and setting the injection up as it should, I;ve always done this and never had a problem, Show you how good it ismy CTi gave 137bhp on a RR day for figures only
PhilCTI
Thanks Miles for the reply,
I was just going on what others had said on here especially after installing an induction kit, but if it can be done by any decent tuner thats fine.
Maybe its a bit chav boy racer but I've never been near a rolling road in my life and sounded like a bit of fun after months of hard work being cold, stuck in the garage, rebuilding her!
Phil.
