MartinR 0 Posted February 17, 2006 Trying to work out which KMS box i need, the one for coils with or without drivers. Many Thanks Share this post Link to post Share on other sites
DrSeuss 0 Posted February 18, 2006 No, they are 'dumb' hence the cars they came out of having ignition modules. Share this post Link to post Share on other sites
petert 607 Posted February 18, 2006 (edited) No, they are 'dumb' hence the cars they came out of having ignition modules. Beware that you can get "dumb" and "intelligent" ignitors, not coils. The Bosch 008 ignitor for example (found in some Volvos), is intelligent, meaning that it has dwell control, requiring an ECU with a "constant duty" output. It will calculate and maximise the charge time needed for ANY coil. A dumb ignitor however, like those found on 205/405's, require a "constant charge" output. The amount of charge time is expressed in msec. On an aftermarket ECU with "constant charge" output you have to manually set the charge time, usually with the aid of an oscilliscope. You cannot mix and match ignitors. A Bosch 008 ignitor will fail instantly if connected to a constant charge output. The S16 has two ignitors. I don't think they're intelligent. Some new coils, like the Chev LS1 coil, has a built in constant charge ignitor. Edited February 18, 2006 by petert Share this post Link to post Share on other sites
petert 607 Posted February 19, 2006 (edited) Trying to work out which KMS box i need, the one for coils with or without drivers. I have no experience with the KMS, but I'd say it's like an Autronic ECU, where it only has a constant duty output as standard. If so, you'd need a Bosch 008 ignitor(s) or a CDI unit. Adding the drivers probably gives you the ability to have a constant charge output, enabling you to run dumb ignitors. Edited February 19, 2006 by petert Share this post Link to post Share on other sites
MartinR 0 Posted October 12, 2006 sorry for being shít, but im still lost............................. I have a mini cooper coil pack and I also have a 405 coil pack. Sorry about this but i am a total nub when it comes to car electrics. Right this is my perception of it (feel free to bat me down in flames if i am wrong) If i use the 405 coil pack........... I will have to use the ignition modules from the 405 (of which there are two of them) and wire these inline between the coil and the KMS If i use the mini cooper pack, i can plug straight from the KMS into the coil pack................ Any help always appreciated Regards Martin Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted October 12, 2006 What 405 is the coilpack from? I've just got a loom from an MM 8P 405 today & that has no ignition module so I'm guessing the drivers are either built into the ecu or the coil pack. The coilpack looks identical to the one I have on my MP3.1 which has an ignition module. Graham. Share this post Link to post Share on other sites
MartinR 0 Posted October 16, 2006 Hi Graham No clue what they came off of, i just wanted the themostat housing and coil packs from a 405 lol. Im so so lost, i just dont want to blow loads of money buying the wrong things..... or worse.... wire it up wrong, blow up my KMS ECU unit and end up throwing money down the drain Share this post Link to post Share on other sites
Rippthrough 98 Posted October 16, 2006 Hi Graham No clue what they came off of, i just wanted the themostat housing and coil packs from a 405 lol. Im so so lost, i just dont want to blow loads of money buying the wrong things..... or worse.... wire it up wrong, blow up my KMS ECU unit and end up throwing money down the drain I'm not 100% but I think the drivers are on the ECU. -Phillip Share this post Link to post Share on other sites
smckeown 1 Posted October 16, 2006 I'm not 100% but I think the drivers are on the ECU.-Phillip They normally are built into in ECUs arent they. They were taken out of KMS for better heat management; if I correctly remember what QEP told me. Matt@QEP and Julian@BalanceMotorsport both offer good advice about KMS..... Share this post Link to post Share on other sites
Rippthrough 98 Posted October 16, 2006 They normally are built into in ECUs arent they. They were taken out of KMS for better heat management; if I correctly remember what QEP told me. Matt@QEP and Julian@BalanceMotorsport both offer good advice about KMS..... Yep, although why they didn't just heatsink them I'll never know. -Phillip Share this post Link to post Share on other sites
pug309twin40s 1 Posted October 17, 2006 (edited) if there the coils you got from me then it was from a 2lt 8v 405/306 engine. xu10j2 Edited October 17, 2006 by pug309twin40s Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted October 18, 2006 if there the coils you got from me then it was from a 2lt 8v 405/306 engine. xu10j2 Paul, do you remember what management system was fitted to this car? I'd guess it was MM8P & if it is then I think the drivers are in the ecu. Does anyone know if the MP3.2 from the 2.0T engine has an ignition amp fitted? Graham. Share this post Link to post Share on other sites
pug309twin40s 1 Posted October 18, 2006 Paul, do you remember what management system was fitted to this car? I'd guess it was MM8P & if it is then I think the drivers are in the ecu. Does anyone know if the MP3.2 from the 2.0T engine has an ignition amp fitted? Graham. urm the normal 2lt 8v system. mm8p sounds about right. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted October 18, 2006 urm the normal 2lt 8v system. mm8p sounds about right. Yeah, if its from an N/A 2.0 XU10 then its MM8P, thats what was fitted to all 2.0l 8v's. Graham. Share this post Link to post Share on other sites
sonofsam 5 Posted October 18, 2006 Does anyone know if the MP3.2 from the 2.0T engine has an ignition amp fitted? Yes it does:) Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted October 19, 2006 Yes it does:) Thought it would've had cos the MP3.1 has. I'm sure they use the same coilpack though so I think they will be "dumb" as suggested originally & need something to create the drive (ecu or ignition amp). Just done a quick search on gsf & they list the same coilpack for the 1.9 8v & 2.0 8v fitted to most of the ~06 Pug's (N92512). Graham. Share this post Link to post Share on other sites
Anthony 1,003 Posted October 19, 2006 Yeah, if its from an N/A 2.0 XU10 then its MM8P, thats what was fitted to all 2.0l 8v's. That's not quite strictly speaking true - early 2.0 8v's (605's and I'd guess XM's) ran MP3.2 management with ICV (that's where I got NickR's setup from aggggess ago if you remember), but yes, certainly the common 2.0 8v implimentations in the 306, 405, ZX, and Xantia's are MM 8P Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted October 20, 2006 That's not quite strictly speaking true - early 2.0 8v's (605's and I'd guess XM's) ran MP3.2 management with ICV (that's where I got NickR's setup from aggggess ago if you remember), but yes, certainly the common 2.0 8v implimentations in the 306, 405, ZX, and Xantia's are MM 8P I mean't 405's specifically as that was what we were discussing as to where the coilpack had come from. Graham. Share this post Link to post Share on other sites
