casnell 0 Posted February 17, 2006 Hi guys, I'm rallying a 205 in OZ and looking advice re strut top mounts. I'm using Drummond adjustable coil-overs on the front, but the mounts don't seem up to the job, any suggestions? Thanks, Chris Share this post Link to post Share on other sites
engine killer 6 Posted February 17, 2006 there is a eccentric one from TAS which you will have camber adjustability. unfortunately you have castor degree adjusted each time you change the camber degree which may cause uneven castor degree. i bought one from Japanese (CUSCO) and it worked fine. based on the japs one i made a castor adjustable top plate and finally comes up with camber AND castor adjustable top mounts. http://community.webshots.com/album/540539824CebECt take a look at this link, you will know what i have gone through. also, the CUSCO one is not too expensive compare to the TAS one, it was about 120-150 quid. Share this post Link to post Share on other sites
Jonmurgie 2 Posted February 17, 2006 TAS aren't around any more... are you actually after more camber/castor or just a stronger top mount? Share this post Link to post Share on other sites
casnell 0 Posted February 19, 2006 TAS aren't around any more... are you actually after more camber/castor or just a stronger top mount? Strength mainly, camber adjustment would be good though... Share this post Link to post Share on other sites
Sam 4 Posted February 20, 2006 (edited) www.compbrake.co.uk are about cheapest. Edited February 23, 2006 by pugtorque Share this post Link to post Share on other sites
casnell 0 Posted February 23, 2006 www.compbrake.co.uk are about cheapest. Thanks for that they look good, just have to see if they send to Australia... Share this post Link to post Share on other sites
petert 601 Posted February 23, 2006 Use modified WRX mounts. Share this post Link to post Share on other sites
Jonmurgie 2 Posted February 23, 2006 WRX mounts... that's interesting, can you share some more info on that? Share this post Link to post Share on other sites
C_W 3 1 Cars Posted February 23, 2006 (edited) Don't you just hate it when someone slips a small nugget of information then doesn't expand on it!!! Edited February 23, 2006 by C_W Share this post Link to post Share on other sites
petert 601 Posted February 23, 2006 (edited) There's nothing secret about it, just use aftermarket WRX top mounts and redrill the tower for the bigger PCD. Depending on which strut you use, you may have make a custom nut for the shaft. They also do a mod with the bearing from memory. Contact Wuillemins in Sydney. Edited February 23, 2006 by petert Share this post Link to post Share on other sites
casnell 0 Posted February 26, 2006 There's nothing secret about it, just use aftermarket WRX top mounts and redrill the tower for the bigger PCD. Depending on which strut you use, you may have make a custom nut for the shaft. They also do a mod with the bearing from memory. Contact Wuillemins in Sydney. Thanks Peter, will try. The mounts from the UK were 80quid, not too bad, but 48 quid postage! Share this post Link to post Share on other sites
