pablo 0 Posted February 12, 2006 (edited) hey all - just had the Mi16 rebuilt after severe bottom end failure. To stop it happening again we are gonna do a few mods to keep an eye on things. Any information on the following would be very much appreciated: - fitting oil temp gauge - fitting oil pressure gauge - fitting oil cooler Just dont trust the std gauges so new 52mm jobs will be just the ticket. Also a decent oil cooler up front should keep temps down. The car will be track only use so temps being too low shouldnt be a problem! Re the oil cooler can we pinch one from a diff car? And where does one obtain a sandwich plate etc from. Thanks all -pablo Edited February 12, 2006 by PPP_Racing Share this post Link to post Share on other sites
jonD6B 0 Posted February 12, 2006 Demon Tweeks have a good selection of gauges and should be a good source for an oil cooler if you choose to buy new. Share this post Link to post Share on other sites
dee205 3 Posted February 12, 2006 As said on here before, oil temperature shouldn't really be an issue and the need for an oil cooler even on a track car isn't so important. I've had many a hairy session with little change in temperature. Having the right oil and changing it regularly matters more. I can't see guages stopping a big end from falling off either. Was oil starvation the cause of failure? Damien Share this post Link to post Share on other sites
pablo 0 Posted February 12, 2006 As said on here before, oil temperature shouldn't really be an issue and the need for an oil cooler even on a track car isn't so important. I've had many a hairy session with little change in temperature. Having the right oil and changing it regularly matters more. I can't see guages stopping a big end from falling off either. Was oil starvation the cause of failure? Damien mechanic reckons it was oil temp couple with a tired old engine really. oil cooler isnt really essential but the gauges would be good. Is it easy to fit a pressure and temp gauge to the Mi? thanks all Share this post Link to post Share on other sites
dee205 3 Posted February 12, 2006 Are the guages on the dash working? Replacing the sensors for new ones may help if the old ones are fecked. Guages shouldn't be too hard to fit if you want new ones. 1 wire from the sensor to the guage and an earth from the guage afaik How did the mechanic diagnose oil temperature as reason for failure? Didn't think you could. Damien Share this post Link to post Share on other sites
pablo 0 Posted February 12, 2006 wasnt so much a diagnosis as a feeling mate - trust him 100% tho knows the engines inside out. dash gauges dont work and arent usually too accurate from what I believe so rather have some more accurate ones in. Cant afford another rebuild lol! Share this post Link to post Share on other sites
jonD6B 0 Posted February 13, 2006 After market gauges are a doddle to fit. You'll just need to pick up the feed from the original senders. Share this post Link to post Share on other sites
pablo 0 Posted February 13, 2006 After market gauges are a doddle to fit. You'll just need to pick up the feed from the original senders. excellent thanks mate where would one find the sensors for the oil temp and oil pressure? thanks again for the help ps - does that mean use an electric pressure gauge rather than a mechanical one? Share this post Link to post Share on other sites
Dream Weaver 2 Posted February 13, 2006 Oil temp is on the bottom of the sump, oil pressure senders are on the block under the inlet manifold. Share this post Link to post Share on other sites
pablo 0 Posted February 13, 2006 Oil temp is on the bottom of the sump, oil pressure senders are on the block under the inlet manifold. Excellent thank you very much mate Share this post Link to post Share on other sites
dee205 3 Posted February 13, 2006 ps - does that mean use an electric pressure gauge rather than a mechanical one? Yes. You should try and get the dash guages and stop lights working though as it's hard to miss a big red STOP flickering on the dash even if you aren't looking directly at it. Damien Share this post Link to post Share on other sites
