dodsworth_gti
Over Heating
dodsworth_gti
just taken her out for a good drive and she has still got the overheating problem!!when going steady,the heat will sit at one piont which is still over hot!!but when you put foot down,the heat rises straight up to the second to last bar!!and to add to things the fan dont work!!this might sound stupid but what is the thing that bolts into the rad that has wires on it??as one of the wires has come loose and pulled out!!any help would be much apperciated
hengti
screwed into the rad under the top hose?
that's the fan switch
j_turnell
whats the condition of your radiator like?
dodsworth_gti
yeah i gether that is what it is!!it is a brand new rad though
Rob_the_Sparky
Not necessarily, a poor thermostat can restrict the flow as well. Oh and get those fans fixed sharpish if you want to avoid replacing the head gasket!
Rob
Richie-Van-GTi
is it running lean at all?
alexi
second the thermostat check, its easy to check if it works/ cheap to get it checked at a garage and if it is faulty its cheap to replace. If the car was fine one day then the next day it overheated then the thermostat could be stuck in the shut position and this will cause major overheating, hapened to me.
worth a check before you buy a new radiator.
yorkshirekowboy
yeah, check the thermostat!!!! that what was wrong with mine, and i went out and bought a new rad!!!! oh well made the engine bay look nicer!!! is your car running lean?, as i have had also experiences with lean running xu's and therefor heat being a prob!!!
also try the top expansion tank cap, as these are prone to crack under the cap ; the metal seal/spring causing problems.
collateral
This sounds semi-similar to what's been happening with mine. Getting the thermostat looked at on Friday, so fingers crossed it's that.
