rooster
Worried ,oil Breather
rooster
ok i have a 1.6 CTI
i went to top up the oil (have small leak only small amount lost over 4 months at a time)
the breather filled with brown soup , now i have had a new head gasket and head and the car does not use coolant at all as i havent filled it for 6 months and the mark hasnt moved in the coolant tank.
so is it condensation ??
i have a stainless filter with no oiled cloth in it , i was summising that damp air be let in more
plus i turned the engine on after the oil top up and opened the breather cap and it was like a volcano spitting brown oil at me ;)
im confused and im worried it may be the start of something expensive :blink:
ok to sum up
1 car running fine no overheating etc
2 no coolant loss
3 rattles a bit when starting up from the top of the engine then settles down
4 soup in breather but not on dip stick
was it just water in the breather bit coming out, will this evaporate if i run it a while
confused big time
let me kmow your thoughts please
tidypug
I wouldn't worry about the mayo you've got in the filler neck, in the winter its a common problem. Use the search button its been covered many times before.
mickie
quick question, will a 1.9 OIL FILLER BREATHER fit a 1.6 one, sorry for off topic, cant fine anything in search
