macaroni
Tu5 Engine With Tu3 Inlet Manifold?
macaroni
There is a very good chance that my tu3 engine is lunched, I will know by this weekend. If so, I have been thinking of replacements and would like to consider a vtr engine. I don't want to be bothered with the engine management side of things, so wondered if I could use my tu3 inlet manifold and carb on a tu5 engine?
I realise I would need some sort of dizzy converter and loads of other stuff.
Is this a viable route or am I p!ss!ng in the wind?
allanallen
if your head is good then just use the bottom end of the vtr you need the vtr cambelt, and you need to drill the holes out on the alternator pully to fit the bottom end and you need the back water hose from the vtr block (the one that goes to the radiator) well woth doing
oh and the flywheel cover off the vtr
Edited by allanallen
macaroni
Cool - what about using a dizzy/carbs/manifold etc?
Is the clutch bigger on a 1.6TU than a 1.4TU?
DaveW
also you have to cover over the injector holes too, not sure on the manifold tho cant see why it wont tho...
allanallen
its all the same, use the 205 flywheel and clutch, the carb is fine the jet is small but will do the job you can get the vtr head converted to dizzy for around 100 but in my opinion it works really well with a xs head on vtr bottom mine is stripped out, and has vtr bottom end and standard xs head and does 1/4 mile in 15 seconds (yes im still moddin it) thats quicker than some 2litre turbos!!!!!
oh and the standard carb!!!
macaroni
Sounds good. I realise what a numpty I am, obviously if I use the xs head, I get a dizzy thrown in for free!
I don't have a standard carb, I have a Weber 38DGAS and the 1.4 is a bit too small for it, but the 1.6 should be just fine. I am getting more excited by this every minute!
I hope my block is cracked!!
DaveW
im sure my mate runs his vtr engine on a 38 tho it dont run great but ive not seen him for ages....
allanallen
ha ha whats the weber off? im puttin a twin choke 34-36 weber on mine off a pinto
p.s your exhaust manifold will also fit
Ted
might be wise to do a search about putting the xs head on the vtr bottom end, i'm sure there were compression issues to over come.
allanallen
nope mines done 4500miles still sweet no problems
DaveW
yeah i sam try it got real high compression ratios
allanallen
high compresion is good
mine also is pretty economical
macaroni
My Weber was off Ted!
Is your engine still at large Ted?
Chances are it will just be a head/gasket problem with my engine, but I suspect a cracked block/liner.
Rippthrough
Would the dizzy need adjusting to compensate for the higher compression? Or is the ignition advance on these fairly mild anyway?
Ted
yes it is... PM if interested...
christopher
This should work fine. But remember you have fairly small valves on an XS compared to 1.6 TU/TU24 and probably ports too
allanallen
no, the inlet valves are slightly smaller on the xs not even 1mm
stu_woac
on the tu3 head the vavles are not domed so you get alittle more of a compression but not to high mines been running out on track now for 5000 miles gets the crap drove out of it still going strong
