Frequentflyer
Cti - Door Cards
Frequentflyer
My current door cards finish some two to three inches from the top of the door - level with the top of the speaker grill - leaving a strip of body coloured paint before you reach the rubber window seal.
Can one find door cards - for a CTi - that will cover the whole door? In what respects are CTi doors different to any other 3 door 205 models? In other words can one use door panels off say a GTI on a CTi?
Also what about the cards under the opening rear quarter light in a CTi - same question?
Thanks for any input.
Roy
DaveW
i dont think theres much difference on the door card part from it has the huge door lock pin which the base models use, you just need to retro fit the thin door lock pin so its like a gti one.
Guest nigeltwo205s
Hi
I've seen a Gti door card modified to fit by cutting round the locking pin. the top will fit under the window rubber but you will probably need some glue to keep it all down.
The one I saw looked good though, so if you're good at this sort of thing give it a go.
Nigel
205 Cti
205 Auto
Guest smokinslim
The rear cards are different shape to standard ones. I've jus got a set of grey cti ones off ebay for next to nothing, much better than the standard blue interior of my cj (grey's still pants tho so they may get painted yet!)
DaveW
Hi
Nigel
205 Cti
205 Auto
i did this on my old 1.1 while it did work, it looked awful as it looked hacked about so i fitted the thin pin type which was a pain but worth it :D
