christopher 5 1 Cars Posted January 29, 2006 I was stripping a TU24 engine and a TU5j4 block (from a 106 Gti) and seeing if I can transfer bits across. The main issue I have seen seems like the iron TU5 block is shorter then the TU24 block. In addition to this the water pump on the TU5 is is screwed into the block. Whereas on a TU24 alloy block this is contained in a cast housing that is bolted to the block (which also doubles as an engine mount). So there are a few of you that have TU5 engines in a 205 (some 8V and some 16V). How have you solved the problem with the engine mount? I know Sam has a custom one but what about the rest? How am I going to solve this?? Is there a standard one that fits? Share this post Link to post Share on other sites
Sandy 191 Posted January 29, 2006 When you say the TU24 block is taller, do you mean overall, or from the crank centre line? The Iron block has an alloy engine mount casting the bolts on where the water pump housing goes on the alloy block. the rest is the same. Sam's custom one was to improve the clearance for the twin DCOE inlet manifold. Share this post Link to post Share on other sites
christopher 5 1 Cars Posted January 29, 2006 (edited) When you say the TU24 block is taller, do you mean overall, or from the crank centre line? The Iron block has an alloy engine mount casting the bolts on where the water pump housing goes on the alloy block. the rest is the same. Sam's custom one was to improve the clearance for the twin DCOE inlet manifold. Ok I only measured roughly..you are right I should measure from the crank I'll do that...for the rest look at the photos...You understand what I mean? Are you saying that I use teh standard 106 mount in a 205? Edited January 29, 2006 by christopher Share this post Link to post Share on other sites
Sandy 191 Posted January 29, 2006 The bit that bolts to the block on the 106, and the normal 205 TU top arm bit. Share this post Link to post Share on other sites
stu_woac 1 Posted January 30, 2006 yes the arm that unbolts from the top of the tu3 bolts straight to the tu5 unsure on the tu24 as this would be different for the carbs right?? Share this post Link to post Share on other sites
christopher 5 1 Cars Posted January 30, 2006 yes the arm that unbolts from the top of the tu3 bolts straight to the tu5 unsure on the tu24 as this would be different for the carbs right??' Yes the ally water pump casting on the TU24 is special because it allows room for the twin 40's. and this has a plate with 3 studs that screw up into the mount I suppose. Now I am just wondering if the 106 mount will allow for the twin 40's. Being a slightly different configuration then Sams (I have a longer inlet tract) . Does anyone have any pics of the 106 mount? Share this post Link to post Share on other sites
Sam 4 Posted January 30, 2006 Don't know about the longer inlet tract? I'm not sure how different the inlet on the TU24 is though. But you will have issues with your inlet and clearance for the engine mount. You'll have to test fit it and see really. Share this post Link to post Share on other sites
TB_205GTI 1 Posted February 2, 2006 What bout the mount from a 205 forever? It uses the 1.4 TU with iron block. A mate is using this engine in a 205 with the Rallye webers. Share this post Link to post Share on other sites
DaveW 6 Posted February 2, 2006 whats a 205 forever....?? Share this post Link to post Share on other sites
Hilgie 16 2 Cars Posted February 2, 2006 one of the latest 205s (1996/1998) Share this post Link to post Share on other sites
christopher 5 1 Cars Posted February 2, 2006 What bout the mount from a 205 forever? It uses the 1.4 TU with iron block. A mate is using this engine in a 205 with the Rallye webers. Who is that Pete? Do you know what mount he is using? Share this post Link to post Share on other sites
TB_205GTI 1 Posted February 2, 2006 Who is that Pete? Do you know what mount he is using? It's André from hi-speed (think his name is Andre205xs), dunno about the mount, but he can shoot some pictures of it if you like. Share this post Link to post Share on other sites
DaveW 6 Posted February 2, 2006 one of the latest 205s (1996/1998) ah we dont have them over here in the uk, all the late 205's that age where autos.... Share this post Link to post Share on other sites
christopher 5 1 Cars Posted February 8, 2006 Ok it has just occured to me that the Rallye uses a GTI shell. So I reckon the genine mount is in the XU location and not the TU location. So none of the above methods will fit Anyone confirm?? Back to the drawing board Share this post Link to post Share on other sites
Sam 4 Posted February 8, 2006 The euro rallye runs a weird mount position like the old XY engines, unfortunately not the same as UK Rallye and TU/XU models. Share this post Link to post Share on other sites
