yorkshirekowboy
Cant Get My Pug 205 In 3rd Gear? Why? Help!
yorkshirekowboy
Hi,
when i started my pug this cold morning i left it running to get warm, when i came back i heard a grinding noise, squeky noise coming from my transmission!!! It must have been my gear box!! the car was in neutral, and it seem it was in 3rd gear as u could feel it pulling the car abit hence the noise!!! i have noiced my clutch was slipping the night before, but now i cant get my car into 3rd, even when the engines off, it feels like thiers somthing in the way of getting of 3rd gear. all the other gears work fine!! Can it be my clutch? or is my gear box knackard?
Help would be very welcome!!!!
Dan
Richie-Van-GTi
sounds like the synchromesh has gone inside the gearbox, is it a 1.6? Ive got a spare box I'll sell cheap and not too far from you.
Redtop
You'll have to take the gearbag out now anyway to get a better look and fix the problem. Seen 206's having a crunching problem going inot 3rd, and it's been the synchromesh that has gone and needed to replace 3rd gear as well. Hard to say for def at the minuite though, but sounds like you'll need a good mechanic on the job to possibly give the box a good overhaul.
yorkshirekowboy
hi,
yeah my cars a 1.6 my other 205 had no trouble with gears werid. that gearbox? is it the reverse one behind 5th? as mines a phase two
thanks
Richie-Van-GTi
nope its a lift reverse above first.
