5150maxie 0 Posted January 28, 2006 just fitted new oil seal to the drivers side but is still leaking?ive got new drive shafts.the seal is not to far in as the picture says in the haynes manual.the seal is not that tight when i test fitted it to the lumpy bit on the shaft before fitting,plus the seal looks different to the one i took off it fits the same thow.do peugeot stock these or to they need to be ordered? Share this post Link to post Share on other sites
Ahl 4 Posted January 28, 2006 Don't worry how it looks, they do look different, but all your seeing is a different outer seal/protector. It sounds like you either haven't pushed it in enough (it should be flush or so) or you've caught and damaged the inner part of the seal when putting it on. Very easy to do unfortunately. Share this post Link to post Share on other sites
5150maxie 0 Posted January 28, 2006 Don't worry how it looks, they do look different, but all your seeing is a different outer seal/protector. It sounds like you either haven't pushed it in enough (it should be flush or so) or you've caught and damaged the inner part of the seal when putting it on. Very easy to do unfortunately. just put another one in and is still leaking.there is still oil coming out so i am leaving it till it is dry then put the shaft in.the seal is perfect no damage.mmm Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted January 28, 2006 you sure its coming from that seal? could be from the seal on the speedometer drive housing or the speedometer drive itself. Wipe it clean with tissue then leave it and wipe agin. If its leaking round theother areas it will show straight away on tissue. Share this post Link to post Share on other sites
Redtop 14 2 Cars Posted January 28, 2006 Had taht problem myself last week. You need to really tighten up the carrier bearing 11ms. The drive shaft slots in nice and well, but the oil seal needs to be over the lug on the drive shaft. Thats why you have to pull the bearing in tight. The ds oil seal is different now because it's superseeded. The oil seal you have now is common on all pugs petrol and diesel so yes your local pug garage should stock them and if not they need slappped. lol. Just let the car sit over nite with a clean sheet of cardboard under it to make sure, when you've the job done. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted January 29, 2006 just put another one in and is still leaking.there is still oil coming out so i am leaving it till it is dry then put the shaft in.the seal is perfect no damage.mmmHave you fitted the driveshaft & checked if its leaking then?? With no driveshaft in it'll drain straight out!! Graham. Share this post Link to post Share on other sites
5150maxie 0 Posted January 29, 2006 (edited) Have you fitted the driveshaft & checked if its leaking then?? With no driveshaft in it'll drain straight out!! Graham. just finshed putting her back together oil seal looks ok. took her for test drive and the car started pulling to left anf right when i back of i thougth here we go again looky it was ony down the road from my house. i jacked her up and tightend the clamp bolt up super tight it wasnt tight enough, what stupid idiot i checked it but did not double check as you do with 205s. my car is now untilted using qep manifold spacer kit.i can really rev it and not worry about oil serge as it was always on my mind when i drove it.now i am going to drive it how a mi16 205 should be im having some fun.(until the next time something goes wrong ha ha) Edited January 29, 2006 by 5150maxie Share this post Link to post Share on other sites
