Jer309GTi
405 Rear Suspension
Jer309GTi
As above really, was just wondering if the 405 rear beams have the same troubles as 205/309 beams with the bearings failing and ruining the tube? I'm guessing its a very similar design, just bigger. Thanks
B1ack_Mi16
I find the 405 ones to be worse, as the shaft is pressed into the beamtube (not replaceable), and the bearings is in the trailing-arms. Meaning the shafts are not replaceable like on the 205 and hence you would need a completely new beam-tube to refurb it properly.
And they seem to fail just as badly too, judging from my 405 and the ones I looked at in the scrapyard for a replacement :blink:
I've also heard they are worse than 205 beams & cost more to fix.
Graham.
KRISKARRERA
Glad Miles did mine a few years ago then.
The new Civic has a torsion bar.
Jer309GTi
Oh dear, I thought as much. Thanks for the replies everyone :blink:
Edited by Jer309GTi
