simon205Mi16
Oops! Dont Think This Looks Too Good!
simon205Mi16
Just went out to top up with oil as its been sounding a bit tappety the past few weeks when cold. B) opened up the bonnet took off the oil filler cap and was confronted with this................ :)
Also after filling it up with some oil i started it up and reved it from under the bonnet and held it up around 2K and the cams seem to be vibrating or something in the head area... :o
Any ideas on what and how????
ANDYGON
you added oil because it sounded tappety?!? did it need oil in the first place? i normally use the dipstick. :)
as for the mayo thats fine i had more than that this morning. just clean it out.
jonD6B
If the mayo stuff is normal what does it mean if you're not getting any at all? :)
simon205Mi16
it was tappety so i checked the dipstick first :)B)
and was just under min....
So is this mayo normal on the Mi as i have noticed it takes an air feed from the manifold inlet just after the filter so surely it would get some moisture from that??
hengti
mayo's fine, but no mayo's better
all the mayo is is condensation in the pipes mixing with the oil - resulting in the yellow gunk. It's most likely to produce it after a short run because the engine doesn't get hot enough to evaporate the moisture
simon205Mi16
Yeah that is true i dont take it that far aint done a long run for ages, only too and from work about 20 mins
hengti
that'll be it then
did you manage to get your track rod end off by the way?
simon205Mi16
I havn't around to go and buy new ones yet not going to be for a couple of weeks, off to the brean rally next weekend so cant do it then so might have to be week after if im lucky
KRISKARRERA
Ahh the good old mayo myths. Read any guides or mags on 2nd hand car buying tell you to run away fast if there's mayo on the oil filler cap..... They neglect to mention that many cars' engines get mayo naturally and that it's not always indicative of a blow head gasket. I've found long journies don't burn it off unless you're doing 100mph +.
Might be worth worrying about if you still get it bad in the middle of summer.
simon205Mi16
Will have to burn up and down the ring roads at 100 + :)
Yeah will definatly get worried if its still there in the summer. if we get a hot summer B)
eddie_1.9
I was just getting rid of my mayo, officer...
Edited by eddie_1.9
jim205GTI
Yer some nice stretches along the ring road to open the car up ................. the part from longwell green to the roundabout for the a4 is nice :)
