simon205Mi16
Track Rod Ends?
simon205Mi16
Where is the best place to buy 2 new track rod ends and how is the best way to get a seized one off? :P
I have 309 running gear on my 205 :) so do i still need 205 track rod ends or 309??
Also with the tracking how is the best way to set this up??
Many thanks all :)
sonofsam
GSF or Eurocarparts would be my choice,i think 205 and 309 ones are the same.
seized track end might mean a new a whole new tie rod,maybe wrong though!!
Tracking i would get done proffesionly,ie not quickfit..Pro tyres is supposed to be good.its in Fareham,amybe a little far for you though
simon205Mi16
I have had to do the tracking myself after putting the 309 stuff on but only adjusted 1 side :P
I know not the way to do it but thats the only thing i could do, as it was completely un-drivable.
Im going to get it done properly this time one the new ends are on, i was just wondering what measurements are best as im sure 205 set-up wouldn't really work due to the wide track!
hengti
Not sure what settings you should use - but can recommend having it set up by Protyre - there's one in Bristol (Laurence Hill). £23.50 for a front set up - the machine they use is v impressive and gives you a print out of the various geometry measurements
Re. getting the old TRend off; I'd just stick at it with WD40 and the spanners - and maybe a lump hammer. It really should come off without having to resort to using an oxy-torch to heat it up. Alot of these cr*ppy places get the blowtorch out as soon as the first attempt at loosening the nut fails - the problem is that once you've heated it up and quickly adjusted and tightened everything again, it's still hot - and once its cooled down you're not going to be loosening that nut again easily!! If you have to use a torch, leave everything to cool down before reassembling - and use a load of grease as well
simon205Mi16
Ill have to spend a wh8ile on it then to get that nut loose.
getting it all set up i can get done in mums work they got this new 4 way computerised thing i just need to know what settings to get it set up on ?
Simes
I have 309 running gear on my 205 :P so do i still need 205 track rod ends or 309??
Many thanks all :)
They are both the same.
