maxi
Anyone Really Know The Spec Of The Mi16 Touring Car Engine
maxi
Anyone got the actual specs of the touring car Mi16 engine??
There was a picture posted on here a while ago of it and I cant find it now. Id like to know about the breather system setup it used as I think a lot of issues on my new engine are also being caused by my setup not being able to cope.....
Any ideas chaps??
Maxi
Sam
Heres some pics I have:
http://dcoe.net/gallery/btcc/
What problems are you having? The Mi16 breather system is pretty complex from what I remember.
maxi
Lots!!!! Pushing oil seals out all over the place, losing oil you name it ive got it!
Maxi
easypug
OK, not that this helps much but my engine (not the engine its self) claims to be an old race engine. It has an extra out let on the head at the back and an extra one on the sump aswell. I never saw the engine installed in a car so can't comment on what its uses were. Maybe a PM to Andy Kirk (person i got the engine off) on here could clear things up about that?
edit to add pics:
Picture 1
Picture 2
Edited by easypug
maxi
That union in the sump I expect was to allow the breather tank to drain back any oil collected back into the engine.... how is your breather system setup dave??
Maxi
easypug
I not sure how it was done to be honest, best bet to find out would be Andy Kirk or GlenF as they took the engine out the car it came from. I never got any pictures of the engine when it was in the 309 (i didn't even see it) so can't help there, i'm not sure if Andy did.
Sam
You really don't want all the "gunk" draining to the sump.
Robsbc
Maxi
Who built this engine? Nothing to do with their building skills?
Don't forget engine's like ours using forged pistons will consume oil for a starters.
Edited by Robsbc
That drains in the wrong side of the sump Dave as the position has changed to the back edge, Can't say anymore for obious reasons
Henry Yorke
Almost looks like a turbo set up, but I don't think it was turbo'd IIRC
maxi
Not me, Nick and Matt.
Are you having any problems with your engine at all Rob?? Breather wise what setup are you running?? Why do forged pistons mean the engine consumes oil??
Maxi
B1ack_Mi16
More cylinder-clearance due to they expand more than standard cast ones.
So more oil consumption...
Sure you don't have to get your engine run-in maxi, the pressure in the crankcase should drop when the rings start sealing better...
maxi
Its done 800 odd miles now and has been getting a thrashing for the last 300..... a compression test showed 245PSI across all four cylinders so it is very high compression......
As for forged pistons, I didnt know that!
Maxi
mfield
A friend of mine had his pinto engine tuned and for the first few months it spat oil out, he would half fill his catch tank every 100 miles !! now it's all run in not a drop goes to the catch tank :o He also had leaks from the odd seal and sump but they've stopped now to. For the record he had a 2.1 conversion which i pressume involves a rebore like your self.
I had the same compression as you but on my 8v and used a small filter as my breather and that resulted in the top hose popping off and spraying oil every where, the filter was fine and you could breath through it with no real pressure but still didn't let the crank pressure out !! after removing the filter no more oil leaks :o
Edit: neither engine had forged pistons
Edited by mfield
maxi
Thats originally what we thought about breather problems that something was restricting it. Thing is, everything now apart from the cam cover (returns back to the block via the union just below the head gaskett- where pug designed it to go) runs to an oil filler that vents to air.... maybe my vents arent big enough?? Im using the std S16 filler with the two smaller outputs just venting to air. Ill take a pic or 2 later.
Maxi
Edited by maxi
mfield
Where does the head vent to, have you got something like a piperx filter ?
I wondered where the crankcase pressure vented on the later blocks :o Would you be able to try venting the block to atmosphere via a catch tank ? ( or coke bottle as a quick test )
The filter i used was about 80mm long with 40mm dia, abit like a minnie 8v air filter except it looked like a k&n with the metal gause. Yet that still wouldn't work !!!???!!?
maxi
Look up and read my last post again mate. The head/cam cover on a later block vents to a union in the front of the block at the very top just under the head gaskett.. Im just going to vent everything to air I think, can anyone see a problem with this??
Maxi
mfield
My bad , read it wrong. thought it said everything except the cam cover goes to the union then out throught the oil filter :)
Nothing wrong with venting to air, just gets oily near the vent if there's nothing to catch it .
Mark
All I know is they had steel cranks, longer Chev V8 rods, custom liners, 35mm buckets and 8500 redline.
maxi
  DrSeuss said:
Alistairh took this picture of a grp. a 306 Maxi :P Maxi :)
http://ben.loaded.net/gallery/view_photo.p...id=Picture_1548
i can't identify half of the bits on it tbh, but its properly bling.
Mr Seuss, I think you have shed some light on a very difficult subject!!! Im off to design a catch/filler tank!
Maxi
Mandic
It's dry sumped so they can mount it a bit lower + maybe they don't get as much oil stuck on the exhaust side, etc.
Ziga
ablister
looks like even touring car's are held together with cable ties!
