Kenno 3 2 Cars Posted January 12, 2006 Hi, have looked at the wire in theradio bay no connectors but here is the wire colors Thick: Green/Yello, Blue, Off White, Thin Twisted with each other: Yellow & White, Red & White, Blue & White, Green & White. I have a new ISO Block to connect but dont want to muck up. All help would be great Share this post Link to post Share on other sites
Kenno 3 2 Cars Posted January 12, 2006 OK just incase I have done a search on the topic to no avail Share this post Link to post Share on other sites
kate205gti 4 Posted January 12, 2006 u got a pic kenno? Share this post Link to post Share on other sites
Kenno 3 2 Cars Posted January 12, 2006 Left to Right Thick: Green/ Yellow, Off White, Blue, Thin: Blue & White, Red & White, Yellow & White, Green & White. Cheers Hope that helps Share this post Link to post Share on other sites
timmsy19 3 Posted January 12, 2006 Left to Right Thick: Green/ Yellow, Off White, Blue, Thin: Blue & White, Red & White, Yellow & White, Green & White. Cheers Hope that helps green/yellow= ground which will go to black cable on headunit off white = negative(i think) - yellow depending on heat unit may not be needed blue = positive - red not sure about thin wires i done it by trial and error. had to do both mine and my brothers cars Share this post Link to post Share on other sites
mareksio 0 Posted January 12, 2006 Just wired mine up yesterday - found this topic useful for sorting out what goes where: Wiring Marek Share this post Link to post Share on other sites
Kenno 3 2 Cars Posted January 12, 2006 yep thats its thanks all for your help sounds soon in car i hope. Share this post Link to post Share on other sites
timmsy19 3 Posted January 12, 2006 yep thats its thanks all for your help sounds soon in car i hope. good luck m8 it can be pain in the arse if they have been cut by a complete numpty Share this post Link to post Share on other sites
jim205GTI 3 Posted January 14, 2006 mine were butchered aswell but a mate suggested using a bulb to test which wire was which by the bulb lighting up i just did some educated guesswork and got it right thankfully Share this post Link to post Share on other sites
