Guest donny206
307 Cable Shift Fitting
Guest donny206
I have done a search but just wanted to ask a few questions!
Will the 307 cable shift with the 307 box fit on to a 206 with out much problem?
What will i have to do to get the cable shift to fit in the 206 origional place? I have pretty much sorted how to get the box fitted but just a little worried on the cable shift, also what will i need from the 307?
Hilgie
I would use the 307box, with the 307 shifting mechanism on top of it. Cables and gearstick from a phase 2 206.
This should work (maybe with a little modification to the cables).
Hilgie
The later types do. For example my wifes 206 1.4 HDI from 2003 does have cable shift.
Guest donny206
ok so as the be4 and ma boxes both fit the tu engine, so will i be able to find a cable shift from a 206 that already is fitted on the ma box as then it will be a straight fit will it not!
Edited by donny206
