Guest ecosseroy
Gti Problem
Guest ecosseroy
i have a problem with a car iam tryin to sort this is a black 1.6 gti 205 f reg,its slammed 60mm on 17s with a full magnex system,chipped and has a pipercross filter,when you turn to the left the car makes a grinding noise?but what it sounds like is the engines moving to the right wen am turning left?any suggestions???
kate205gti
check the engine mount under the battery tray? can you move the engine at all in the engine bay?
Butler
Check the engine mount on the drivers side.
Can you rock the engine side to side? If the drivers side engine mount is knackered the engine hits the inner wing and makes a horrible vibration noise.
Guest ecosseroy
just checked the engine its not excessively wobbling but i can move it
Butler
Can you make the engine hit the inner wing on the drivers side. You'll see its quite close.
Have you checked the tyres and inner wings for signs of rubbing.
Edited by Butler
Guest ecosseroy
yip bangin off inner wing thanx for the help on that the mounts have been ordered
