James_R
Think It's New Engine Time
James_R
Well after just joining the pug community and buying a 205 Mi16 I'f had my first french car mishap, happened at failry high revs and speed, something let go and here's the damage. Cracked liner, no piston no exhuast valves and a dead head. Hopefully it will be possible to stick a new liner pistons and rod in, but alot of water went in all the inlets so coudl have hydrolic lock on th eother and bent the rods, so maybe new engine time. Only owned the car for 1 day. Still live and learn i guess.
Any donation are welcome at this time. :)
James
easypug
I'd get the crank checked before you think about using it. Oh yeah, welcome to pug ownership :)
edit: Just to let you know your not on your own, I had a cam belt go on me in a 205 Mi16 on the first day the insurance started bent all 16 valves!
Edited by easypug
pug309twin40s
oh. you certainly made a mess of that engine.
bad luck for only having the car 1 day!!
Gavin Waddell
thats fubar.
but how did zou get so much water in there, big puddle?
James_R
thats fubar.
Cracked the liner
boombang
I blew up my Mi about same day it was rebuilt, running it down Santa Pod :ph34r:
j_turnell
Thats very unlucky, the whole engine will need to be stripped down and measured up to get the full extent of the damage.
ALEX
It would be cheaper to buy another engine and use that one for spares.
James_R
That's the plan I thin Alex, just hope the crank is ok, that's the main bit. and 6 inlet and exahust valves, lol
S33GAV
Bad luck. Another mi dies, something that's becoming an all too comon occurence. Rebuilding these tired and ragged engines is the only way to go it seems...
Good luck
James_R
The engine was only 4k old from the last rebuild
hman205
what spec was the old engine?
Did you find the remains of the missing piston?
James_R
Was a just a std rebuild by Miles aka pugracing nothing fancy. The remains of the piston are visible in th epic the two balls of metal at the base of the bore.
I've still not taken the bottom end out the car yet, cause it's raining, and I'm waiting till I've got a replacement before I crack on. I'll give it a quick sump off to see what's what down there when I get it out though.
hman205
The piston looks to have melted not good
