sorr
Lazy Fuel Pump
sorr
My fuel pump has decide to only work when it wants. When I turn the ignition on it does not prime so the car will not start. But if you leave the ignition on for 4 minutes or so the pump starts so off it goes.
It cannot be the tachimetric relay as a previous owner must have hard wired the pump. (Must fix that at some point)
Any suggestions?
Check that you are getting 12v across the two fuel pump terminals, but assuming you are, just replace the pump - there's plenty of them out there and they're generally fairly reliable.
ashley peddle
well i bought 2 duff ones before i found (stole :P) one from a mate... seems to have sorted the problem now :)
