jerseypug
14 X 62 On Crown Wheel
jerseypug
i have a gearbox from my mi16 and am not shure what type it is as the guy i bought it off had lots of work done on it. the crown wheel has 14 x 62 stamped on it. does anyone know what final drive this is. i am hopeing that it is a mi16 so i can put it into a 1.9 box. if so can i slot it straight in or does the gear that drives it on the 1.9 box need changing as well? any help will be appreciated.
62/14=4.428
And you need to change both of the gears - the one that's on the output shaft (the difficult one), and the one that's bolted to the diff (the easy one)
Hilgie
14x62 should be from a 405Mi16.
