Guest doggydowg
Mi16 Alternator Uprated?
Guest doggydowg
Hiya guys i need an alternator capable of running a minimum of 100amps the mi16 one makes 80amps which isnt powerfull enuff, are there any other peugeot alternators which are powerfull which will bolt on my engine?
Thanks Paul.
ellisg
Pug recommend replacing Mi16 alternators with Mitsubishi ones, if you look in parts CD you will see part number for Mitsu alternator to replace mi16s
Guest doggydowg
n1 not sure if it is 80 or 90 a member said it was 80 might be 90 i need a 100+ alternator to power my amp as it keeps cutting out and going into protect mode as there is not enuff power for it `1580rms think there is a way of working it out like 1580/14.5 meaning i need an alternator that is 108amps.
thanks Paul.
where is the parts cd just searchd cant find sorry.
boombang
Don't forget that a lot of those amps will go on actually powering the car!
Do you not have a local ICE specialist / auto electrical specialist who can rewind the alternator to produce more ampage?
I take it also you are not running a split charge system with suitable level of capacitance?
Guest doggydowg
would be allot better of i could get a company to mod my alternator to make more amps, im going to local ice shop 2m to see what i can get away with and without replacing, might be able to just run it with a 1.5 farad capacitor but doubt it.
at the mo i am running no cap btw, i have emailed a company off of ebay who mod alternators and sell them for £200 but its a bit ott for a car stereo.
if anyone can list part numbers for mitsibushi alternators that fit on my 1.9 mi16 engine that would be realy usefull as i suspect they are allot more hardcore then the peugeot ones i have been looking at;-)
Thanks Paul.
