pacey205 2 Posted December 30, 2005 Can anyone tell me where the fuel pump earth is ? Ive been told its by the passenger side tail-light but wanted to check before I start taking things apart (its cold, and pissing it down outside). Michael Share this post Link to post Share on other sites
Guest pistonbroke Posted January 1, 2006 The earth is just in front of the passenger rear light, there is a multi pin earth, cant remember which wier it is (poss yellow/brown or blue/black), there is also a connection under the rear seat about 6 inches from the pump. Its worth checking this too. Share this post Link to post Share on other sites
Guest wils3 Posted January 1, 2006 The fuel pump earth is like said above, just in front of the rear left light unit. It should be a yellow connector connected up. There should be 4 earth wires comin out of yellow connector. Wire no: M76 = Fuel Pump Earth wire Wire no: M65 = Fuel Sender Earth wire Wire no: M87 = Washer Pump Rear Earth wire Wire no: M1 = ???? Share this post Link to post Share on other sites
