Guest oli205
Oh Bollox
Guest oli205
unplug coil, take out spark plug, screw in comp tester then get assistant to crank car over for a few sec (keeping foot flat on accelerator)
read figure off comp tester, write it down, then move onto next one :unsure:
OK, you'll have to ellaborate a little bit on that if you can, I am not much of a mechanic!
How do i:
-Unplug the coil?
-Crank the coil over?
Cheers!
rich_w
How do i:
-Unplug the coil?
Cheers!
to unplug the coil i would remove the multiplay connector at the top of the coil, i'm guessing you have a late 205 so the coil should be a black blob on the inlet manifold.
You can't crank the coil :unsure:
Cranking the car = trying to start the car (igingtion swtich pos 3), as you have unplugged the coil the car wont fire thus it won't move.
You need to do it for about 3/4 seconds (maybe a bit less maybe a but more).
Make sure you put the spark plug back in tight (but not silly - the hanyes manual gives you an idea of what they should be) you don't want them flying about
