cybernck
The Definitive Weights Thread
cybernck
Has anyone got a pair of driveshafts to weigh please?
And does anyone have skills and time to make a nice Excel sheet or a simple categorised table with all the data from this topic? :)
Toddy
Cybernck - I have it in Excel which I can Email to you, just tried to post it up but it goes out of sync. Cheers
Edited by Toddy
not the greatest weighing implement, but a rough indication nonetheless.
XU10J4RS cylinder head complete, covers cams valves pulleys, no thermostat housing or vacuum pump, 27 kilos.
IMAG2764 by WELSHPUG, on Flickr
XU7JP4 engine block, liners and mains caps present and all bolts, 25 kilos.
IMAG2763 by WELSHPUG, on Flickr
XU10J4RS engine block - 44 kilos.
IMAG2762 by WELSHPUG, on Flickr
later XU10 aux/engine mounting bracket, 5 kilos.
IMAG2759 by WELSHPUG, on Flickr
XU10 crankshaft, 15 kilos.
IMAG2757 by WELSHPUG, on Flickr
Bendix/Bosch rear brake calipers. 3.5 kilos.
IMAG2760 by WELSHPUG, on Flickr
306/xsara hollow cast type hub carrier wheelbearing and drive flange, 4.5 kilos.
IMAG2758 by WELSHPUG, on Flickr
Edited by welshpug
cybernck
306 GTI-6 rear caliper without pads - exactly 2 kg
I'm guessing the 205 GTI one is about the same :).
stu8v
I removed the PAS setup from my VTS engine and rack
Big front engine mount,
2x tensioner pullies,
Pipes flexi and hard,
Header tank,
Ram,
Rack heat shield
PAS pump,
Belt.
All that lot 15kg
Ron_Jaegers
What would be the distribution of that weight over the mentioned components Stu?
hoodygoodwood
205/309 GTI 'fat' starter motor = 10lb 4oz , Peugeot OE 'slimline' starter = 6lb 4oz .
Obviously there will be some variation depending on brand etc of starter but a 4lb saving has got to be good news .
4 short headed GTI wheelbolts = 15 oz
4 long headed GTI wheelbolts = 1lb 3 oz
A 16 oz saving for a full set .
  On 3/14/2015 at 12:48 PM, hoodygoodwood said:
205/309 GTI 'fat' starter motor = 4.65 KG , Peugeot OE 'slimline' starter = 2.84 KG .
Obviously there will be some variation depending on brand etc of starter but a 1.81 KG saving has got to be good news .
4 short headed GTI wheelbolts = 0.43 KG
4 long headed GTI wheelbolts = 0.54 KG
A 0.45 KG saving for a full set .
I really think we should stick to metric units in this thread!
RossD
EW10J4S (206 GTi 180) engine - Fully built with manifolds, mounts, flywheel, clutch, starter, alternator - 135Kg (No fluids)
BE4 5 speed Gearbox - 34Kg
Iron block TU 1.6 8v engine - Fully built with manifolds, mounts, flywheel, clutch, starter, alternator - 118kg (No fluids)
Edited by RossD
Simmo
Removed my sunroof assembly today - 11.8kg
That includes the glass, the metal frame, handles and pipework, bolts and exterior plastic trim...
Simmo
Bare C5 alloy wheel (PS811815) - 4.8kg
Probably already posted but couldn't see it... anyone tried doing a linkable excel spreadsheet with this lot on...?
Simmo
16 Citroen wheel bolts to suit C5 alloy wheel - 1kg
16 standard flat washer wheel bolts for 1.9 alloy - 2kg
dcc
Doesnt sound right to me, unless its an xu9j4
definitely an 8v, says 129ch.
wicked
The same doc for the XU9J4 says 132kg for the XU9j4 including, starter, alternator and fly..
After a bit of searching, I found the 1.9 Mi16 (XU9J4) version of that series of technical documents.
http://ddata.over-blog.com/4/23/45/11/XU9J4.pdf
Without flywheel = 112.6kg
With flywheel (and clutch?) = 121.6kg
With starter and alternator = 132.7kg
Looks like comparing like for like, the 16v engine is around 13kg heavier than the 8v (100, 108, 119kg).
I'm struggling to find similar documents for later XU engines, but it's probably reasonable to assume that the equivalent weights (including flywheel/alternator/starter) are those I listed back on page 9. There's still something a little odd with the XU10 figures though.
i know from comparing the XU7 block directly against the bare XU10 block that there's 18 kilos in it as well, but is that 112 kilos including manifolds? it sounds like it given I've weighed a bare 8v at 78 kilos.
I recently weighed an almost bare TU5J4, it came in at a hefty 100 kilos.
barneys66
These may well have been posted before, but was swapping wheels yesterday, so..
Painted C5 steelie with majority worn 195/50-15 Toyo R888 - 13.1kg
4 x wheelnuts for above - 232g
Original Speedline with slightly worn 195/50-15 Michelin PS3 - 14.7kg
Refurbished SMR with slightly worn 195/50-15 Michelin PS3 - 16.0kg
4 x wheelnuts for above - 416g
Random Peugeot Quartz 15" wheel trim - 730g
given the C5 wheel is known to weigh 4.7 kilos give or take, and the speedlines about 8 kilos.
worn R888 - 8.4 kg.
slightly worn PS3 - 6.7 kg.
mmt
Flywheel weight.
5.9kg for 1.6 GTi
6.9kg for 1.9 GTI
6.5kg for Motronic 1.9
Edited by mmt
calvinhorse
TU 8v engine cam pulleys
Tu1/2/3 - 625g
TU5 - 450g
Piper - 350g
lahondal
The car i have built for my friend is a xu10j2te engined 205, with fiberglass boot, bonnet and front wings, perspex windows. Fully stripped and only 1 bucket seat.
Full custom simple wiring for rallying (lights, horn, etc).
826kg in weight scales
hoodygoodwood
For comparison purposes here is some 309 info , my cars weighed on my Intercomp EZ weigh scales .
309 GTI Goodwood , 5 door , Speedlines , 1.6 flywheel -- 950.5 KG
309 , 3 door , started as a 309 XL so no sunroof , PAS , electric windows , C locking . Full GTI running gear -- 903.5 KG
