JRL 14 1 Cars Posted July 17, 2010 I have finally got round to removing the underlay my god did it stink and crumble as i pulled it away. also removed trim here and there except dash and door cards I then took it to the local dump and weighed it. 820kg I cant believe the difference. Share this post Link to post Share on other sites
christopher 5 1 Cars Posted September 9, 2010 The offical weight of a Euro 205 Rallye is 675kgs. ( I guess that is a dry weight perhaps?) It makes for the cheapest road tax here Some other reports say 790k'gs (wet maybe?) Share this post Link to post Share on other sites
swordfish210 20 Posted October 27, 2010 The offical weight of a Euro 205 Rallye is 675kgs. ( I guess that is a dry weight perhaps?) It makes for the cheapest road tax here Some other reports say 790k'gs (wet maybe?) 675 seems seriously light for a standard Rallye, i'd believe the 790 myself. Share this post Link to post Share on other sites
Henry 1.9GTi 36 Posted October 28, 2010 how much were the C5 wheels new swordfish? and could you remind me of the weight again please I assume they are the same width and offset at a 1.9 wheel? Cheers, Henry. Share this post Link to post Share on other sites
welshpug 1,675 Posted October 28, 2010 ET18 x 6", prices and exchange rates have risen, so best to enquire with your local dealer (or scrapyard...) Share this post Link to post Share on other sites
swordfish210 20 Posted October 29, 2010 I paid £200 for all 4 inc VAT but as WP says, the prices seem to be going up so best to ask a dealer. I think they weigh 4.8kgs each. Share this post Link to post Share on other sites
trogboy 17 Posted November 16, 2010 Anyone know the weight of a front subframe? GTi specifically but I doubt that the base model one is much different. Cheers, Ad Share this post Link to post Share on other sites
swordfish210 20 Posted November 22, 2010 Anyone know the weight of a front subframe? GTi specifically but I doubt that the base model one is much different. Cheers, Ad The subframes are pretty much the same weight, gti wishbones are the heavier bit. Share this post Link to post Share on other sites
Jamal 2 Posted January 30, 2011 15" 6J ET19 306 Xsi/405 LeMans Laser alloys with original paint and center caps: Italian(Speedline): ~9,95kg UK made: ~10,95kg Share this post Link to post Share on other sites
BusEngineer 7 Posted February 19, 2011 Just been all the way through this thread and i cant find the weight for a 405 Mi16 alloy? Any ideas people? Share this post Link to post Share on other sites
stebbs 5 Posted February 27, 2011 Does anyone the weight saving to be had by changing the standard fuel tank for an atl fuel cell or alloy tank taking about 40 to 50 litres? Cheers Share this post Link to post Share on other sites
EdCherry 34 1 Cars Posted May 12, 2011 Quaife 5.2kgs Tran-X 4.9kgs Share this post Link to post Share on other sites
Cameron 16 Posted June 7, 2011 Any idea what the standard diff weighs, Ed? Share this post Link to post Share on other sites
EdCherry 34 1 Cars Posted August 20, 2011 Not yet cameron, will get it out at some point. Anyone got the weight of 1.6 rear drum brakes including handbrake cables and front struts including springs and top mounts? pretty pretty please! Share this post Link to post Share on other sites
dave205 19 Posted September 21, 2011 Rear hub with and without wheel bearing? Share this post Link to post Share on other sites
welshpug 1,675 Posted September 21, 2011 bearing is part of the hub Share this post Link to post Share on other sites
dave205 19 Posted September 22, 2011 bearing is part of the hub Its not if you remove it when its knackered Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted September 22, 2011 306 GTi-6 rear hub with bearing and 4 steel wheel studs sticking out - about 2300-2400 grams. It's slightly longer than a 205 hub and with an ABS ring, so I reckon close to 2000 grams without the studs for the 205 hub. Front 306 GTi-6 hub slightly less than 6 kg. Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted September 28, 2011 o.e 205 GTi wishbone inc Std rubber bushes 5 kgs I've just weighed my 309 GTI wishbones (complete) and they were like 2.5 kg each . Anyone know the weight of an Mi16 sump? Share this post Link to post Share on other sites
EdCherry 34 1 Cars Posted September 28, 2011 4mm Lexan 2x Front Windows + 4mm Lexan 2x Rear Windows - Roughly 6.1kgs. Share this post Link to post Share on other sites
wardy18 33 1 Cars Posted November 10, 2011 Anyone know the weight of the Phase 2 Black Coolant Header Tank? Have trawled this thread and its not been posted Cheers Simon Share this post Link to post Share on other sites
welshpug 1,675 Posted November 21, 2011 not much browsing a friends build thread on the 306gti6 forum I came across these; ML5 Gearbox - 50.5kg with selector fork GTi6 Gearbox - 40.2kg with selector fork GTi6 Inlet Manifold Complete - 9kg GTi6 Exhaust Manifold - 5.7kg V6 Inlet Manifold Complete - 6kg GTi6 engine with plugs, cambelt aux tensioners, PAS + alternator, flywheel and clutch (no wiring, most water hoses) - 145kg V6 - too heavy for the scales (over 150). V6 Standard Flywheel - 8.1kg (mine is expected to be about 7kg - safety first!) V6 Standard Clutch - 7.2kg Share this post Link to post Share on other sites
EdCherry 34 1 Cars Posted November 21, 2011 AST 3-Way Front Dampers - 4990g - Top Mount, Remote Canister, Casing and Main Tube. Without Spring. 6505g - With Spring. AST 3-Way Rear Dampers - 2295g - Remote Canister, Main Tube. Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted December 9, 2011 I weighed my standard shocks and springs as well as rear dampers today: OE front shock absorbers with standard springs and top mounts - about 7 kg each OE rear dampers, one dead/empty so possibly lighter than the other - just over 3 kg the pair Share this post Link to post Share on other sites
sorrentoaddict 1 Posted December 12, 2011 a Dell'orto 40 DHLA carby, empty, no horns = cca. 1230 gr. Share this post Link to post Share on other sites
