welshpug 1,675 Posted January 26, 2010 V6 Lightened flywheel as mentioned above ended up at 7.1 Kilos courtesy of one of Andy Gwynne's contacts Majority of weight taken from outer edge whilst maintaining a decent thickness (10mm min) and no sharp radii. Share this post Link to post Share on other sites
brumster 135 1 Cars Posted February 12, 2010 Weighed the car on proper corner weight scales; 910Kg all-in. Don't have the splits handy, but that is :- 1.6 non-sunny gti shell, welded-in 6pt cage, additional strengthening plates in various places, seam welded, iron-block S16 (trimmed engine mount; TB's), 5sp box, carbon bonnet, stripped interior but standard dash, lightened bootlid, spare wheel, 1/4 tank fuel, plus all the related stage safety gear (two extinguishers, swirl pot, etc). Sump guard was off it at the time, and no bodies in it either. Share this post Link to post Share on other sites
JRL 14 1 Cars Posted March 7, 2010 I have started stripping the rear of my car, i am keeping everything in the cock pit . I will be weighing all the parts after they are out: Have a guess how much it all totals up to and i will let you know this week... Spare wheel wheel cage. boot tray boot mat boot underlay rear seat belts rear seats rear inner wing carpet. rear grab handles trim around the windows rear speaker cover trims seat brackets loads of screws parcel shelf this has all piled up to a mountain in my garage. I reckon it will weigh 20 -25kg????? Share this post Link to post Share on other sites
badj 0 Posted March 9, 2010 I have started stripping the rear of my car, i am keeping everything in the cock pit . I will be weighing all the parts after they are out: Have a guess how much it all totals up to and i will let you know this week... Spare wheel wheel cage. boot tray boot mat boot underlay rear seat belts rear seats rear inner wing carpet. rear grab handles trim around the windows rear speaker cover trims seat brackets loads of screws parcel shelf this has all piled up to a mountain in my garage. I reckon it will weigh 20 -25kg????? I'd guess at more 30-35kg, assuming the spare will weigh near 20 on its own. all the little bits add up. Share this post Link to post Share on other sites
Paul_13 212 1 Cars Posted March 9, 2010 My floor and bulkhead underlay weighed at least 20-25kg by itself, might of been a tad wet! Share this post Link to post Share on other sites
JRL 14 1 Cars Posted March 9, 2010 Thats brilliant cant wait to weigh them i hope your are right and it is more. Share this post Link to post Share on other sites
badj 0 Posted March 19, 2010 '91 1.1 carby Trio S Sun roof model SMR pepperpots No carpet/underlay Rear Seats & Shelf removed Still with some junk in the car, £10 of fuel, spare wheel still on etc. Which ain't bad IMO Share this post Link to post Share on other sites
JRL 14 1 Cars Posted March 20, 2010 mate that is brilliant people consider a sub 1000kg car light but a 700kg car is feather light. I have stripped the rear of mine leaving the cockpit as standard I have not driven it yet but today I cleaning it inside I leant on the rear panel and it rolled forward so effortlessly Share this post Link to post Share on other sites
badj 0 Posted March 20, 2010 mate that is brilliant people consider a sub 1000kg car light but a 700kg car is feather light. I have stripped the rear of mine leaving the cockpit as standard I have not driven it yet but today I cleaning it inside I leant on the rear panel and it rolled forward so effortlessly I still have some removing to do, and could still replace the glass and swap for glassfibre bonnet and hatch, seats that would be lighter than standard (not hard) etc. but i still have bits to put on, including the engine. I'm hoping I could get the weight to 800kg with a 1.6 8v in it. if that were the case, then it would have the same power/weight ratio as an E36 BMW 328i. in theory anyway... which would be nice. Share this post Link to post Share on other sites
JRL 14 1 Cars Posted March 20, 2010 yep power to weight gaining and saving is quite addictive dont you think? I am going to take my bits down to the scrappy and weigh them. I have a smart roadster coupe fanstastic little car i use everyday handles really well better than any pug i have owned it weighs 800kg or less the engine weighs less than me but kicks out 101 bhp and still gives me 50+ mpg. Share this post Link to post Share on other sites
welshpug 1,675 Posted March 22, 2010 XU10J4R cylinder head complete, inc cams + Pulleys, alloy cam covers, no thermostat housing, 26 kilos. XU7JP4 (LFY) 8 counterbalance crankshaft, bare, 13.5 kilos. BBM Solid rubber XU bottom mount bush 466g. XU7JP4/10J4R standard cast iron 4-2 exhaust manifold, inc fire ring, 6.25kg. XU9J2 flat top piston, 398g. XU9J2 gudgeon pin, 129g. XU7JP4 piston, 332g. XU9J4 D6C piston, 362g Share this post Link to post Share on other sites
hexhamstu 9 Posted March 25, 2010 anyone know the weight of a rear beam? Share this post Link to post Share on other sites
welshpug 1,675 Posted March 25, 2010 alf a feking ton! complete? discs or drums? dampers inc? Share this post Link to post Share on other sites
ifcho 0 Posted March 26, 2010 anybody know the weights of mi16 and DFZ rods? Share this post Link to post Share on other sites
hexhamstu 9 Posted March 26, 2010 Complete 205 1.9 beam with no brakes, with or without shocks. Share this post Link to post Share on other sites
welshpug 1,675 Posted March 26, 2010 Stu, I found earlier on 306gti6.com that a 306 beam packaged on a pallet is about 65, a 205 beam wont weigh a massive amount less. Share this post Link to post Share on other sites
Batfink 201 Posted April 23, 2010 '91 1.1 carby Trio SSun roof model SMR pepperpots No carpet/underlay Rear Seats & Shelf removed Still with some junk in the car, £10 of fuel, spare wheel still on etc. Which ain't bad IMO No wonder the tu engined 205s handle well look at the balance left and right! We got a rallye to 750kg with driver with polycarbonate windows, a fibreglass bonnet and the car gutted of anything that could be unbolted or ripped off.. Share this post Link to post Share on other sites
swordfish210 20 Posted April 23, 2010 We got a rallye to 750kg with driver with polycarbonate windows, a fibreglass bonnet and the car gutted of anything that could be unbolted or ripped off.. 750kg is my target for the XT, it's going to be hard with the big brakes and the passenger seat though Share this post Link to post Share on other sites
Cameron 16 Posted April 24, 2010 Did some weighing today, on some scales accurate to 0.1 grammes! I've rounded them to the nearest gramme. 1.9 GTI Girling front calliper (with pads): 4.245kg 1.9 GTI Brembo grooved disc: 4.192kg 309 GTI front upright, hub & wheel bearing: 5.782kg S2 106 Rallye steel wheel with Yoko A048: 14.347kg (185 / 55 / 14) AP Racing Lotus 2 pot calliper: 1.898kg And then weighed my exhaust system: Shortened downpipe: 1.412kg 2.5" inter pipe: 2.260kg 5.5" x 10" oval x 500mm back box (2.5"): 7.908kg Total system weight: 11.58kg Share this post Link to post Share on other sites
RossD 44 Posted May 6, 2010 Fantastic weight on the 1.1 base model above - I'm going to try and get mine weighed sometime as I know someone with some proper corner weight scales.... Would be excellent to be sub-800kg Share this post Link to post Share on other sites
franus 0 Posted June 25, 2010 You can sum up how much I weigh engine 1.9 8V, 1.9 16V (aluminum), 1.9 16V (iron) and 2.0 16V? thx Share this post Link to post Share on other sites
Sobaru' 0 Posted June 26, 2010 So is anybody using the C5 lightweight rims with success and are they easy to find? Could you fit 205/50 tyers on these rims? Are steel rims from a 307 or a 406 any lighter then the standard speedlines? Share this post Link to post Share on other sites
swordfish210 20 Posted July 9, 2010 So is anybody using the C5 lightweight rims with success and are they easy to find? Could you fit 205/50 tyers on these rims? Are steel rims from a 307 or a 406 any lighter then the standard speedlines? I'm using them, i bought them new from Citroen. I much prefer them to the standard speedline wheels, the car feels great when i'm using them. Share this post Link to post Share on other sites
Spiky 37 Posted July 9, 2010 got 12 of them, nice and light cant see 205 being a problem, i'm about to put some 205's on mine Share this post Link to post Share on other sites
