swordfish210 20 Posted February 13, 2008 180mm Sachs clutch (Std patteren part) for XS ect: 0.785kg's 180mm Helix paddle clutch: 1.006kg's Share this post Link to post Share on other sites
willxs 0 Posted March 20, 2008 2x lower GSF arms = 7.2Kg's 1x = 3.6kg's 2x Leather headrests = 1.9Kg's Share this post Link to post Share on other sites
pip470 61 Posted April 19, 2008 can any one tell me the wieghts of a 1.9 front hub with wheel bearin and a 306 gti 6 one please? Share this post Link to post Share on other sites
mafo 0 Posted April 19, 2008 can any one tell me the wieghts of a 1.9 front hub with wheel bearin and a 306 gti 6 one please? 6.1 kg including 4 stubs and aluminium 4 pot conversion bracket. Share this post Link to post Share on other sites
pip470 61 Posted April 19, 2008 which hub is that please? Share this post Link to post Share on other sites
pip470 61 Posted April 21, 2008 Ok weighed some things 1.9 hub with wheel bearing 5.8kg 1.9 hub with vented disc 10.4kg 1.9 hub with solid disc 8.2kg 1.9 front disc(rusty and used) 4.1kg 1.9 rear solid disk (tarox 40 grove) 2.4kg standard 1.6 italian speedline 7.4kg yokohoma 048 196/60/14 tyre 8.7kg s16 crank 17.1kg s16 bare block with mains caps and bored to 87.5 43.8kg Share this post Link to post Share on other sites
pip470 61 Posted May 1, 2008 Ok so it cost me £60 to find this out but a 306 hub is hevier than a 1.9 gti hub, 306 gti 6 hub with bearing 6.1 kg Share this post Link to post Share on other sites
Kobayashi 35 2 Cars Posted August 7, 2008 auxiliary front lamps - might be more useful for parts-posting than weight-saving: 1x SIEM (with plastic housing) 0,475 kg 1x CIBIE Iode 35 (metal housing) 0,610 kg Share this post Link to post Share on other sites
Baz 421 Posted August 8, 2008 8v DKZ Camshaft packed up with 2-3layers of bubblewrap and lashings of brown tape - 2.9 kgs. Underlay from one side of 205 GTi, under carpet, seemingly dry - around 5kgs!! Share this post Link to post Share on other sites
SurGie 54 Posted October 10, 2008 Speedline Turini 7x16CH16 with Sportcontact 195/40/16, 16.3kg. +++ Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted October 10, 2008 now what is that supposed to mean!? Share this post Link to post Share on other sites
Longfield 0 Posted October 21, 2008 (edited) Original 1988 Alternator for my 1.9Gti... 5.8kg. Modern OE replacement Alternator for my 1.9gti [not performance part] 4.6kg Cost £55 +VAT Original 1988 Starter Motor for my 1.9Gti... 5.0kg. Modern OE replacement Starter Motor for my 1.9gti [not performance part] 3.0kg Cost £65 + VAT Edited October 21, 2008 by Longfield Share this post Link to post Share on other sites
jonnygoodhand 0 Posted December 4, 2008 106 S1 Rallye Steel Wheel (5.5j) = 6.5kg S1 Rallye wheel with 175/55 Goodyear GT3 = 13.5kg Speedline SL434 with 195/50 Toyo TR1 = 15.5kg Share this post Link to post Share on other sites
Jamal 2 Posted December 16, 2008 Hi, Fondmetal 4000 6JX14 ET18 alloy with center cap and valve(i hope this is the exact name) without balancing wights approx: 6 kg Share this post Link to post Share on other sites
Rippthrough 98 Posted January 5, 2009 Standard rear 247mm disc - 3000g Lightweight rear 247mm disc - 1900g Sprint rear 247mm disc - 1650g Standard 283mm Xantia disc - 6200g Lightweight 283mm Xantia disc - 4250g Sprint 2-piece 283mm Xantia +bolts - 3750g 266mm 307 2-piece disc - 2950g Share this post Link to post Share on other sites
Liquid_106 97 1 Cars Posted February 24, 2009 Complete drive shaft weight anybody? Off side flavour please Share this post Link to post Share on other sites
Spiky 37 Posted June 5, 2009 gti6 disc and caliper weights? wilwood 4pots like the gti6 guys use? Share this post Link to post Share on other sites
Rippthrough 98 Posted June 7, 2009 wilwood 4pots like the gti6 guys use? 2.5 kilos including pads, clips and the aluminium mounting brackets for Welly's setup with my brackets. Share this post Link to post Share on other sites
TVH 0 Posted July 1, 2009 Anyone knows standard fuel tank weight? Share this post Link to post Share on other sites
sam jfm 0 Posted November 11, 2009 Hi spec billet 4's with pads 285 discs and hoses 17.5KG according to the post office Share this post Link to post Share on other sites
stuart 31 3 Cars Posted November 26, 2009 307 HDi discs, pads, calipers 25.4kg according to the post office - ouch Share this post Link to post Share on other sites
gangsterous 0 Posted December 2, 2009 Had my car on a set of corner weight scales the other day. For those interested. A 1989 1.9 GTi, non-sunroof in totally standard condition to my knowledge. Has electric windows and central locking, half leather seats, etc. Full fuel tank, spare wheel and bracket in the boot. Front washer bottle filled, rear empty. Oil, coolant and brake fluid, topped up. The only items missing that might make a difference are the jack and wheel brace from under the bonnet. There are no mud flaps or foot mats, the parcel shelf is missing, the rear boot panel and badges have fallen off and (along with probably any other French car of a similar age) there are a multitude of nuts and bolts missing from various places. Total 889kg with 63% on the front. Accurate to 0.5 kg. Corner weights were: Left Right Front 274.5 282.5 Rear 170 162 Craig That is actually very interesting to know. So the 930kg was not that accurate. If they weigh under 900kg then Woohoo... Lol Share this post Link to post Share on other sites
Toddy 7 Posted January 26, 2010 Stolen from Adam_B's thread on 306 forum, Cheers Adam! I will update this post as I weigh things... ML5 Gearbox - 50.5kg with selector fork GTi6 Gearbox - 40.2kg with selector fork GTi6 Inlet Manifold Complete - 9kg GTi6 Exhaust Manifold - 5.7kg V6 Inlet Manifold Complete - 6kg GTi6 engine with plugs, cambelt aux tensioners, PAS + alternator, flywheel and clutch (no wiring, most water hoses) - 145kg V6 - too heavy for the scales (over 150). V6 Standard Flywheel - 8.1kg (mine is expected to be about 7kg - safety first!) V6 Standard Clutch - 7.2kg Share this post Link to post Share on other sites
