sonofsam 5 Posted December 14, 2006 Girling front caliper--------------3.8kgs. 247mm 205 front disc------------4.3kgs. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted December 15, 2006 247mm 205 front disc------------4.3kgs. 1.6 or 1.9? There is possibly a slight difference (as small as 100g) due to the different offset. Graham. Share this post Link to post Share on other sites
sonofsam 5 Posted December 15, 2006 1.9. Can weigh up some pads later too. Share this post Link to post Share on other sites
swordfish210 20 Posted January 8, 2007 I recently ripped out all of the soundproofing from inder the carpet in my 205 and it came in at 13.8kg and the only downside is that it's slightly louder in the cabin but to combat this i just turn the sterio up. Win Win situation i think Share this post Link to post Share on other sites
smckeown 1 Posted January 28, 2007 XU 8v head. Fully dressed head, no manifolds and with cam cover. 16kgs Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted February 11, 2007 406 Coupe V6 Brembo 4-pot calipers: 3750 grams per caliper, probably 4 kg with all the fixing and pads. thanks axnutty . Share this post Link to post Share on other sites
welshpug 1,675 Posted March 23, 2007 hey guys, I know as posted earlier in the thread that "S16 engine with all parts on = 160 kg" but how much does a GTi6 engine weigh? Share this post Link to post Share on other sites
kyepan 291 Posted March 27, 2007 (edited) now updated anyone know the following? Bendix front caliper--------------2.2 kgs 247mm 205 front disc------------4.3 kgs Standard front pads---------------approx 1kgs Kgs total for 205 1.6 setup including 4 pads, 2 discs, 2 calipers 14 Kgs 307 Hdi 283mm x 26 brake disc-----6.9 kgs 307 hdi bosch caliper----------5 Kgs Ferodo ds2500 pads--------------1.2 Kgs Total for 307 setup including 4 pads, 2 discs, 2 calipers. 25 kgs... exactly. so to offset the extra unsprung weight, you would need to loose 5kgs a side (oz superlegeras vs standard 1.9 speedlines) Cheers Justin Edited March 27, 2007 by kyepan Share this post Link to post Share on other sites
swordfish210 20 Posted March 29, 2007 just thought i'd add that as far as paint goes...WHITE is the lightest paint you can get. Yay my car is good at something Share this post Link to post Share on other sites
Sandy 191 Posted March 30, 2007 It's also the cheapest colour in the Awlgrip range mostly used in Aviation, and easiest design graphics over. Share this post Link to post Share on other sites
smckeown 1 Posted March 30, 2007 just thought i'd add that as far as paint goes...WHITE is the lightest paint you can get. Yay my car is good at something not according to paintguy it's not. he liosted on here some specific weights for paint Share this post Link to post Share on other sites
SPGTi 2 Posted March 30, 2007 just thought i'd add that as far as paint goes...WHITE is the lightest paint you can get. Yay my car is good at something How do you work that out ? density of a typical white paint is 1.3 density of a typical black paint is 1 A black paint formulated with carbon black pigment has a much better opacity therefore less paint is needed to get full coverage. Therefore even going with using 2 litres of each paint to paint the outside of a car. mass = volume x density white - mass = 2 x 1.3 = 2.6kg black - mass = 2 x 1 = 2kg Steve Share this post Link to post Share on other sites
swordfish210 20 Posted March 30, 2007 a friend of mine who has been spraying race cars for 30 years now in a business that he took over from his dad who was doing it for 40 years told me that white is the lightest colour. I chose to take his word for it Share this post Link to post Share on other sites
sonofsam 5 Posted March 30, 2007 (edited) Technically speaking, white is not a colour at all Edited March 30, 2007 by sonofsam Share this post Link to post Share on other sites
Sandy 191 Posted March 30, 2007 Total colour isn't it? Share this post Link to post Share on other sites
sonofsam 5 Posted March 30, 2007 Combination of all the colors of the visible light spectrum. Share this post Link to post Share on other sites
Leon C 1 Posted April 6, 2007 14" 1.6 GTI Italien made Speedline without tyre = 7.1 kg. Share this post Link to post Share on other sites
welshpug 1,675 Posted April 6, 2007 Valeo starter off a 98 GTi6, 2.81 kg. Aircon pump off same engine, 8.8 kg. Share this post Link to post Share on other sites
Baz 421 Posted May 16, 2007 Std 8v Exhaust Mani (with a bit of bubble wrap and tape) 4.5Kg 8v Valeo OE clutch friction plate (as above, packed) 1.12Kg Anyone know the weights of say a Magnex 4branch or similar, and a paddle clutch, again or similar? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted May 17, 2007 Anyone know the weights of say a Magnex 4branch or similar?Approx 4kg's. Pretty sure its a Magnex one. Kaaz diff, bare diff, no crown wheel etc fitted; 5kg's. Graham. Share this post Link to post Share on other sites
BackStreetRacecars 3 Posted June 5, 2007 Desperatly in need of the weights of 205 1.9 ingine and the weights of the 3.0 v6 in the 406's and xantias..... can anyone help??? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted June 6, 2007 Desperatly in need of the weights of 205 1.9 ingine and the weights of the 3.0 v6 in the 406's and xantias..... can anyone help??? 1.9 8v weight Topic about V6 engine gives an approximate weight of 50kg's heavier than the 2.0t engine. Graham. Share this post Link to post Share on other sites
felix2566 2 Posted November 6, 2007 309 gti four port master cylinder 1.2kgs 406 four port master cylinder 0.6kgs Share this post Link to post Share on other sites
GLPoomobile 958 Posted January 28, 2008 Std 8v Exhaust Mani (with a bit of bubble wrap and tape) 4.5Kg Baz you dong! Get some better scales! I just sent a mani to McPikey (it was one with the extra brace across one half) and it was 5.943kg including bubble wrap. And no, I didn't use 1.5kg more bubble wrap than you Share this post Link to post Share on other sites
andy0075 9 1 Cars Posted February 2, 2008 XU9JAZ crank........14,12 kg XU9JAZ flywheel....6,75kg Andy Share this post Link to post Share on other sites
