Livelee 0 Posted July 7, 2006 309GTi mi16 engine quaife LSD roll cage stripped interior 2 opm seats standard pannels and glass 900kg with 1/2 tank fuel at a local dump weight bridge. Seems very heavy compared to the 205s. What's standard for a 309? Share this post Link to post Share on other sites
Livelee 0 Posted July 8, 2006 Standard 309GTi Rad - 3.4KG Standard 205TD Tad - 8KG :-( Oh well keeping the engine cool is more important than keeping it light. I should manage to brake even on the weight though as most of the stuff i've removed to change the rad won't be going back. Share this post Link to post Share on other sites
KRISKARRERA 2 1 Cars Posted July 8, 2006 309GTimi16 engine quaife LSD roll cage stripped interior 2 opm seats standard pannels and glass 900kg with 1/2 tank fuel at a local dump weight bridge. Seems very heavy compared to the 205s. What's standard for a 309? That's actually very good when you consider a 309 GTI16 is 978kg. Share this post Link to post Share on other sites
Sandy 191 Posted July 8, 2006 Speedline Turini 7x16CH16 with Sportcontact 195/40/16, 16.3kg. Share this post Link to post Share on other sites
Livelee 0 Posted July 9, 2006 mi16 head, complete apart from rocker cover 24.5kg Share this post Link to post Share on other sites
sonofsam 5 Posted July 14, 2006 115/70/15 Space saver spare wheel ~ 9.5kgs. Yeah yeh i know, take the spare wheel out and carry some tyreweld. Share this post Link to post Share on other sites
Leon C 1 Posted August 14, 2006 15" Citroen C5 alloy "steelie" = 4.8kg Share this post Link to post Share on other sites
Powers 13 Posted August 14, 2006 Whats the caliper clearence like on that? Share this post Link to post Share on other sites
welshpug 1,675 Posted August 21, 2006 them steelies are light! what's the dimensions? they're cheap too as I remember someone on PSOOC posted the Price of Michelin steelies and they were something like £180 a set!! Share this post Link to post Share on other sites
Leon C 1 Posted August 27, 2006 (edited) Apparently 206 GTI 180 calipers will fit so caliper clearence isn't an issue. They are 15x6J ET18 and I paid £20 for all 4, but citroen dealers should be able to supply them for £30 ish* per wheel. They are actually made from an alloy and not steel, hence their low weight. Most of this thread is about these wheels: http://forum.205gtidrivers.com/index.php?s...56930&hl=weight Edited August 27, 2006 by Leon C Share this post Link to post Share on other sites
205007 12 Posted September 3, 2006 Std road 205 t16 rim 8kgs without tyre Evo 1 tarmac mag 10" 7.4kgs without tyre Share this post Link to post Share on other sites
Leon C 1 Posted September 15, 2006 (edited) OE radiator = 4.2kg Nissens alloy radiator = 2.6kg Edited September 15, 2006 by Leon C 1 Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted September 16, 2006 standard radiator - 5 kgNissen aluminium radiator - 2.6 kg OE radiator = 4.2kg Nissens alloy radiator = 2.6kg Graham. Share this post Link to post Share on other sites
smckeown 1 Posted October 13, 2006 Some tyres weights: Yokohama Advan A038r 195/50/r15 7.91kgs Avon ACB10 Sport 195/45/r15 6.1kgs Share this post Link to post Share on other sites
crogthomas 0 Posted October 23, 2006 Sound deadening from beneath the carpet on a GTi. Dry (not soaked from all the leaks) - 8kg Share this post Link to post Share on other sites
sonofsam 5 Posted October 25, 2006 OE rear view mirror and metal boss~ 200g. Summit suction cup rear view mirror~75g. Share this post Link to post Share on other sites
welshpug 1,675 Posted October 25, 2006 o.e 205 GTi wishbone inc Std rubber bushes 5 kgs Share this post Link to post Share on other sites
christophe 0 Posted October 26, 2006 a compomotive mo 15" with offset of 15, 6" wide was i think was 6.9KG absolutely bare, it was some time since i weighted them but im pretty sure it was that. Share this post Link to post Share on other sites
Guest rick03054 Posted October 27, 2006 1.9 half leather front seat + subframe - 14.4kg All 4 parts of the 1.9 half leather rear seats - 18.0kg 1.9 inlet manifold, bare - 4.2kg 1.9 AFM - 2.0 Kg 1.9 trailing arm with shaft and stub pin - 7.6Kg TT manifold with studs - 3.6Kg TT manifold + T25 turbo (with actuator, boost solenoid and inlet and exhaust housings) - 12.2Kg Share this post Link to post Share on other sites
smckeown 1 Posted November 19, 2006 Pug OE horns (x2) and bracket (300g each) -------------- 600g Steel Bumper brackets & horn bracket (720g each)----- 1,440g Inner wing brackets (250g each)---------------------------- 500g OZ Ultraleggera 7x15 ET 18 = 5.7 Kgs Avon ACB10 sport wet slick 195/45/15 = 6.1 Kgs Share this post Link to post Share on other sites
kyepan 291 Posted December 13, 2006 (edited) anyone know the following? Bendix front caliper--------------?.?kgs girling front caliper--------------?.?kgs 247mm 205 front disc------------?.?kgs 307 Hdi 283mm brake disc-----?.?kgs 307 266mm brake disc---------?.?kgs Cheers Justin Edited December 13, 2006 by kyepan Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted December 14, 2006 i weighed ALL of that (and more) once, but have lost the paper with the measurements :). Share this post Link to post Share on other sites
kyepan 291 Posted December 14, 2006 i weighed ALL of that (and more) once, but have lost the paper with the measurements . what would be the chances of you weighing what you have lying around? pretty please Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted December 14, 2006 Bendix front caliper--------------2.2kgs. Graham. Share this post Link to post Share on other sites
