Guest andy309goodwood
Cam Q
i will be using a large valve flowed 1.9 gti head on a 2.0 bottem end modded to get 2.1
on a 2.0 t conversion im looking to make the most out of the engine there fore any advise on wich cam to use would be good
having also done a serch on here a few threds aimed to ward a cat cam via mattsav going down the high lift low overlap route . is there an off the shelf solution or will a full custom gring be needed ?
cheers again guys
andy
Mattsav
We've got a couple of options for this.
I'll dig out the email and let you know.
charlie_sav
he was still waiting for his broadband to work again i think his dialup has now given him the boot also.
Mattsav
Whoo Hoo. Broadband is back at last. Just in time as the dialup modem died as well!!
There are a couple of options depending on the spec of the engine.
4900337 on a 114deg centerline.
4900338 Inlet with 4900337 exhaust on a 116deg center line.
4900338 on a 116deg centerline.
Pirce is the same as an off the shelf cam at £169.57 + vat
ok i have absolutly no idear what you just said lol
straight over my head im afraid
spec has slightly changed and is as follows
1.9 gti head with big valves and flowed
2.0 turbo block
1.9 gti l and b crank (to tack me up to 2.1l)
mi16 l and b flywheel
turbo tec exhaust manifold with rollerball t28 and custom made exhaust
gti inlet manifold and mappable ecu to controll fuel ign and boost
what im after is a high lift cam with very little over lap
cheers for ur help
lol just realised ur in burgess hill im quite often doing work down that way
lol
might have to pop in some time
ok spec has changed again lol
im now going to be using a big valve fully flowed 405 sri head would these cam's still be sutable also which one has the higher lift and shorter duration cheers should be ready to order in the next couple of weeks as i need to sent the cam doiwn to the guy thats building the head
cheers andy
