Rob Turbo
Xu10j4 Head On Xu10j2te Block
steendp
The parts catalog seems to indicate that the pistons are dished...
jacobs53
I don't get this at all... I defintly stripped apart both turbo engines and they both had flat top pistons. I wonder if citroen changed the design for any reason? As i stripped apart a 605 and 406 engine.
lee
B1ack_Mi16
I really think there must be 2 versions.
The XU10J2 N/A pistons I had a look at some days ago definately had much lesser dish than the ones on the picture.
Hilgie
The 4 (!) 2.0T engines I stripped (or helped stripping) all had flattops. I assume the above are from a 2.0 XSi engin though. How low do these sit down the bore?
offtopic: those liners seem really badly rusted, I assume he's overboring the engine?
jacobs53
black-mi16 haave you picture of the combustion chamber on the head?
I wonder if a 306 xsi engine has been turbocharged? and passed off as turbo engine.
lee
B1ack_Mi16
lee
Yes, this is the head:
boeseturbo
any updates?
boeseturbo
  boeseturbo said:
any updates?
Hey friends,
I can get a head from Citroen XM 2L 16V with 132 hp (enginecode is RFV). Is that the same head like the 150/152hp engine?
Can I use this head on the turbo-block or I´ve to buy one from the 150/152hp engine?
How big are the valves? And what about cam-timing (good for turbo-applications with not so much overlap?)
Thanks!
Jan
Edited by boeseturbo
Hilgie
The RFV head is similar to the RFS head (the 167bhp engine), but the valves are a bit smaller.
The cam timing is very suited to turbo applications. Infact Gerben from this forum is using the exact same head on his 205 1.9-16V turbo
www.205turbo.nl
boeseturbo
www.205turbo.nl
sounds good, I can get it you 80 EUR´s from a Citroen-driver (think he didn´t know what he sells :D) with 120.000 km with cams and no damages... I think I´ve to buy it hehe ;)
Thanks Hilgie!
Henry Yorke
Gerbens car is rapid too (when he doesn't take it apart again for yet more power!!)
Guest davetibbs
Any news from the original poster? I'm very interested in doing this.
boeseturbo
Hi friends,
I just opened a XU10J2TE spare-engine. This engine didn´t have got flat-top-pistons. They have a big dish in the middle of piston.
enginecode is RGX. At my drivingcar is a engine with RGY-Code. Is the difference between the engines the pistons (RGY has flattops, RGX has got the pistons with a dish?).
Has andybody a picture of the flattop-pistons + engine?
Jan
B1ack_Mi16
  boeseturbo said:
Hi friends,
Jan
I'm pretty sure that the pistons is the difference between the enginecodes.
I've seen several dished versions but never a flat top one.
boeseturbo
yes you are right. Just read it in a french-forum. All RGY-engines have flat-tops (141 hp here in Germany), and all RGX-engines have big dish in the middle of piston (147 hp engine here in Germany).
Jan
Hilgie
Mine is a flattop (RGY).
