Kenballs
Mi16 Clutch
Kenballs
I tried to order an mi16 clutch kit from Peugeot because I'm doing a conversion at the moment but they say they need the chasis number of the mi, which I don't have because I only have the engine. They also say there's two different types of release bearing.
The engine is the earlier alloy block type and I'm using my own 1.9 8v gearbox, does anyone know exactly what part no.s I require so I can get it ordered, it would be much appreciated.
Cheers,
Ken.
Kenballs
Turns out I still don't have permission to e-mail other members, grrr..
Maybe he'll see this and give me a shout.
Bonzai
you should be able to pick up a general Mi16 clutch from a local motor factors. just say what car its from, i.e the year of the 405 the engine came from...
mine cost £60something
Ahl
You should be able to use the Private Messenger Ken.
Kenballs
Didn't know I could do that but cheers Ahl, I'll give it a try later.
Ken.
whizzer71
Depends on the year of your 205,upto 88/89 be1 gearbox early type,be3 89> later type,GSF do clutch kits mail order at a very reasonable price,or alternativley you local motor factor,go for a Valeo or Luk clutch,valeo being oe,luk being nxt best thing.
Good Luck
Tristan.
:D
Well as your using the old 1.9 box you will need the Mi clucth (215mm) as this fit's onto the flywheel and if your car uses the older BE1 (lift reverse) box you'll need the early release bearing to suit the clutch arm
littlemike
I've got a nearly new Luk Mi16 clutch that came out of a Be1 gearbox. If I get a Be3 release bearing will I be able to use it in a Be3 gearbox or is either the pressure plate or friction plate slightly different between be1's and be3's?
