Guest ashnicholls
Which Distributor
Guest ashnicholls
Im going to use 1.6 block, with xu10 head and 1.9 gti cam all skimmed and ported.
should i use the 1.9 distributor, with the better advance curve as i have just got the economic 1.6 distributor.
cheers
ashlee205gti
Im running a 1.9 cam using the standard 1.6 distributer and i havent noticed any problems. IIRC theres only a very small difference in the two cams anyway.
If anyone recommends using the 1.9 distributer then i would be interested on any benefits that can come from it. But saying that im using the standard induction and not carbs.
Guest ashnicholls
no im not expecting the cam to make a difference. i am, but what i mean is will the gti dizzy be alot better than the economical engine.
cheers
Guest ashnicholls
can anyone shed any light on this please?
cheers
Guest ashnicholls
are base model dizzy's and gti model dizzy's the same?
will a 1.6 base model dizzy do the job?
cheers
