munky205
Bonnet Lifters
munky205
Hi,does anyone know where i could find(if they exist)some bonnet lifters to replace the single leg,just about holding my bonnet up at the mo!! Cheers
mbayley77
Do you mean the pneumatic lifters like hold the boot up?
Super Josh
If you're after the tailgate style ones, then people have been known to fit the 106 bonnet lifters, after a little modifying.
Josh
Daz_C
Vauxhall Nova Ones do the job a Treat !
You can get them from here SuperNovas
They fit like this.
Rippthrough
They fit like this.
They don't look overly strong!
Gust of wind and a smack across the back of the head?
Daz_C
They is Very Strong Mate !
When Fully Opened Bonnet sits Vertical and needs a good pull to close it.
Have had them on for years and the bonnet is open more often than shut (as with most 205's) and its never budged on windy occasions.
munky205
Do the ones from novas go straight on or do you have to bodge a little bit?!
Daz_C
No Bodge required. replace the Bolt in the wing with the "Ball"? also replace one of the Hinge Bolts on the bonnet with the other.
You do have to cut the corner out of the support bar so the bonnet will shut over the strut. I Presume U have to do this with any strut though ?
If you look in the picture its where the rubber on the back of the bonnet sits on the scuttle panel. Not Hard if you have a steady hand and Take Your Time.
munky205
Cheers mate,looks like i'll be doing that then as soon as i get my auto bonnet! just a lazy person really,plus the fact that when you tell people you've got an mi lump sat under there(soon to be done)and the bonnet slowly lifts,the suspense of it showing the beast is gonna be great!!
Ben Allen
So the balls literally screw straight in then Daz?
I'm tempted to get one myself as I had my bonnet support savagely broken by some arseh0le who posts on here :angry:
Could you post a larger pic?
Edited by Ben Allen
munky205
Thats exactly what im after,cheers guys and ben,if you get some before me give me a shout on how you get on with them.
Ben Allen
I'll probably get some on order soon.
If you get some before me, however, then let me know what they're like :rolleyes:
Daz_C
Sorry I forgot to put up a Bigger picture.
I purchased another set from Trax - £12.95 made by a company called INXX.
Bigger Picture
Ben Allen
Lovely stuff. When I have some cash I'll get some bought B)
Paintguy
Hmmm...
Maybe fancying some of those myself ;)
Super Josh
Likewise ;)
Josh
Rippthrough
Ordered 3 sets ;)
Bit of jiggery pokeyery and they should fit the mx-5 bonnet and tailgate while I'm at it.
tom_m
mmm me likes :D
Mad Professor
I have brought a set witch turned up this morning.
Just looking at the packing and the ball joint bolts are the worng size.
one has a bigger size threed 8mm the pug one is 6mm, and the other one is more like a screw then a bolt.
Is this the same as what you got, or have thay sent me the worng bit's?
Edited by Mad Professor
Daz_C
Holy s*ite...... I have just looked in the box which I had spare in the garge the one I bought from Trax and it has the same fixings :)
The original one I bought was from a company called Online something or other but they have closed down and the proper fittings were in that kit.
Mad Proffesor you have Pm.
Hilgie
There are two manufacturers: Bonrath and INXX
The INXX ones are incorrect and the Bonraths are no longer produced.
Mad Professor
Does anyone know where I might be able to get hold of the right ball bolt's to fit the pug?
Daz_C
I'm fairly sure 97.5% that you will find them on the tailgate of a Saxo holding the tailgate struts.
benje
No chance you could get a die and recut the thread on the 8mm one down to 6mm?
Ben
