Guest ashnicholls
Gear Linkage Rods
Guest ashnicholls
are the gear rod linkages on base models the same as on the gti models.
car in question is 309 1.1 being converted to xu engine.
cheers.
Col
i dont think so.
Guest ashnicholls
why not, if my car is lift up reverse. and the gti box i have is lift up reverse, and looks similar on the outside?????????
Ahl
Because the cars have different gearboxes!!!!!!!!!!!!!!
The rods are same type, but chances are they are the wrong length. You might be able to adjust them a bit.
Im sure someone knows if they can be made to fit or not.
Guest ashnicholls
ye i know they are diff inside, but if the box looks the same on the outside then surely the rods should be the same.
so you all think i need new rods??????????
niklas
The rods are different, so is the gear change mechanism.
One of the rods are going on the other side of the exhaust compared to the GTI model.
EDIT: "gear change" = lever
Edited by niklas
Guest ashnicholls
oh no thats something else i have to buy
Guest ashnicholls
so what will i need, the rods and the l shaped lever in between rods and gearbox???????
Guest ashnicholls
can anyone answer this, if i bought a set of rods of miles, what else would i need, the L shape lever, which you lengthen to shorten the throw?
sonofsam
3 x rods, plus L shape lever wich you can get from the scrap yard for a couple of quid.
Shorten it to shorten the throw. ie quickshift do you mean.
Also is your subframe pivot point going to be different?
Guest ashnicholls
ok cheers,
i dont know you tell me.
Guest ashnicholls
Is my subframe pivot point going to be different?
has anyone got any of these parts?
cheers
