Jonmurgie
Jenvey Throttle Bodies On The Mi16
tom_m
job done! :huh: looks spot on mate! hope you get some good results from it :)
All looking good Jon, nice to see some real progress happening & it all getting closer to being finished (for now anyway).
Graham.
Dream Weaver
Looks superb, maybe worth putting some mesh over the front of the headlight though, just some thin gauge stuff as panel filters aren't normally exposed to ram air so directly.
Jonmurgie
There is mesh behind the foam... I'll see how well it lasts and decide what to do I reckon, only costs about £30-£40 for a new filter :P
Guest btwstripe
very nice mate, i`m running very similar on my metro vvc
Jonmurgie
Thanks... got a little bit more done at the weekend but this coming week we HAVE to get it finished and running, just waiting for a couple of small parts...
Jonmurgie
Today I managed to get the throttle linkage put together and on the car... it's a nice bit of kit onces it's together but to start off with it's just a bag with LOTS of bits!!
But it does go together...
And once you then spend another age messing about with rod lengths and positioning it eventually ends up looking pretty damned sweet :D
Hope to get the injectors in tomorrow...
Loads more pics here: http://www.mdracing.co.uk/jenvey.asp
Banjo
Looking very sweet mate, any news on your QEP engine?
Ben
Edited by Banjo
Powers
Is you plan to get it running on the throttle boddies for now, then in the Summer remove the engine and fit the one from QEP?
Edited by Powers
Jonmurgie
Yeah, getting the TB's setup and working on this engine for a couple of track days etc. then slot the QEP engine in and re-mapping the TB's to match :D
Just got word that the pistons have arrived... ordering up some more special parts tomorrow... should be a nice little motor when it's done :)
Jonmurgie
Got the injectors sorted and in so far today...
These are 300cc/min injectors from a BMW M3 so shoudl be good enough for my needs ;)
Loom has also started today... more pics here: http://www.mdracing.co.uk/jenvey.asp
Powers
Looking good. Are Power Station making the loom from scratch?
Cheers.
Jonmurgie
At the moment they are making a 'link lead' between the standard engine loom and the MoTeC M48:
And this is the inside of an Mi16 ECU!
They will do me a complete engine loom for the new engine though, should keep things nice and neat... may try to persuade them to do a complete CAR loom to get rid of all the unecessary stuff ;)
veloce200
Looks good Jon! I met Matt from QEP the other day and he was telling me you do all their design. I take it Power Station are a client? Perhaps try and swing a 4wd conversion out of them to? :huh:
DrSeuss
They will do me a complete engine loom for the new engine though, should keep things nice and neat... may try to persuade them to do a complete CAR loom to get rid of all the unecessary stuff :)
Is there a good reason for not using shielded wire Jon?
You only need shielded on the low voltage stuff. ie lamda sensor and trigger(s)
DrSeuss
Correct me if i'm wrong but the CAS is one of the signals your talking about, which would come through the ecu plug....
Jonmurgie
I'm sure they know what they are doing...
Jonmurgie
Got the Oil Catch Tank fitted today... it's a bit on the large side though I'll get a smaller one at a later date:
Quite please with how it's all fitted though, with moving the oil filler too... all works out quite nicely! Filter on the catch tank was £7 from Motorworld, Halfords do the Pipercross ones at £17 but they don't really do much so I don't see a problem in saving a tenner :blush:
Having my doubts that my car will be finished in time for Silverstone next Friday... though knowing PS it will be a last minute rush on Thursday and I'll have NO time to get used to it and see if anything needs tweeking, it will be straight out on track!
that black wire in the background is probably sheilded, and will be going onto some of those unused pins I imagine.
JamieTonks
wow what spec is this and who's is it
Jonmurgie
Have posted in your other thread... very very tasty isn't it :)
ablister
is the inlet manifold a longmans one? I thought they were 2 pieces or is a different one needed for throttle bodies than for carbs?
Jonmurgie
who's... mine (which is a longmans) or that 8v?
Stainless steel is a great application for air boxes as it's a very poor conductor of heat (and electricity). Maybe not as good as carbon fibre, but easier and cheaper to construct.
