stupid205 0 Posted July 5, 2005 does anyone know the big end and mains torque settings on a 1.9 8v 1993 lump??? Anyhelp would be great! thanks Share this post Link to post Share on other sites
smugpug205 0 Posted July 5, 2005 (edited) I take it it's the xu engine, the haynes joke book says main bearing cap nuts and bolts 49nm main bearing cap side bolts 24nm big-end cap nuts stage 1, 40nm fully slacken all nuts, then tighten to stage 2, 20nm stage 3, tighten through a further 70 deg as i said thats the haynes hope it helps Adrian Edited July 5, 2005 by smugpug205 Share this post Link to post Share on other sites
niklas 1 Posted March 15, 2006 (edited) main bearing cap nuts and bolts 49nm I just cannot believe it. Yes I know what Haynes says, and I've raid http://forum.205gtidrivers.com/index.php?s...hl=mains+torque too. But it's just not very tight is it??? Have people successfully put their engines together with just using 50 Nm on the mains???? I want proof before I believe it Edited March 15, 2006 by niklas Share this post Link to post Share on other sites
Bonzai 2 Posted March 15, 2006 i have got a glass's tech service data book from 1988 and the torque settings listed in there are as follows: cylinder head bolts - 60nm - 44 lb ft (loosen, then 20nm/15lb ft +300degrees big end bearing bolts - 50nm - 37lb ft main bearing bolts - 50nm - 37lb ft flywheel bolts - 50nm - 37lb ft clutch to flywheel bolts - 25nm - 18lb ft Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted March 16, 2006 Have people successfully put their engines together with just using 50 Nm on the mains????I want proof before I believe it I used those figures on the engine currently in my car & so far I've had no problems revving up to 7k. (I actually used the Autodata sheet torques as they are more progressive on the headbolts) Autodata tightening torques for a 1990 GTi; Big end bearings; Tighten in the following stages: 1) 40Nm 2) Slacken off 3) 20Nm + 70' Main bearings; Horizontal bolts = 25Nm Verticla bolts = 54Nm. Graham. Share this post Link to post Share on other sites
niklas 1 Posted March 16, 2006 Thanks! Graham: Do you happen to have the full Autodata for download??? Share this post Link to post Share on other sites
