Ryan 99 Posted June 23, 2005 I need to get a replacement for the S-shaped hose that goes from the back of the thermostat housing to the metal pipe that runs along the rear of the head on the mi16. Mine has expanded at one end and doesn't seal properly unless you do the hose clamp up so tight that it's virtually slicing the hose in two! This one: Does anyone know the price from peuegot? Share this post Link to post Share on other sites
petert 601 Posted June 23, 2005 I need to get a replacement for the S-shaped hose that goes from the back of the thermostat housing to the metal pipe that runs along the rear of the head on the mi16. Mine has expanded at one end and doesn't seal properly unless you do the hose clamp up so tight that it's virtually slicing the hose in two! This one: Does anyone know the price from peuegot? <{POST_SNAPBACK}> approx. AUS$75 Share this post Link to post Share on other sites
Ryan 99 Posted June 23, 2005 approx. AUS$75 <{POST_SNAPBACK}> Thats about £33 then! Won't be buying one of those! Share this post Link to post Share on other sites
C_W 3 1 Cars Posted June 23, 2005 Just connect you heater hose direct to that one. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted June 23, 2005 I don;t think Pug do them anymore, And they do have a habbit of doing that whcih is one of the reasons I never use it, Just tig the Ally stat housing up and run the heater hose from the side as the 8v does, That system only works if you have the 16v stat in anyway which most engines don;t have, I should have a hose kicking around of a Tig'd up housing if needed Share this post Link to post Share on other sites
Dream Weaver 2 Posted June 23, 2005 (edited) Thats interesting Miles, so can I also ditch my coolant bypass pipe as well? They are only for getting the heater warmed up quicker anyway as far as I remember. So does that stat pipe just run to one of the 2 heater matrix pipes on the bulkhead then? And what about on the multi union on the block where the bypass connects? Finally, which bit needs tigging/blocking? Edited June 23, 2005 by Dream Weaver Share this post Link to post Share on other sites
C_W 3 1 Cars Posted June 23, 2005 You can use either exit off the side of the head to connect to the heater hose on the bulkhead; I've used the one furthest the back (the one pictured above) as it seems to fit better and blocked the side exit off the head using a stop that came on the BX 16v engine. You'll have to block off one of the exits on the distrubiton block at the back of the block but I've used a metal 1.9 8v one which had one less out put I think. Share this post Link to post Share on other sites
Dream Weaver 2 Posted June 23, 2005 Not sure what you mean either exit. I have that metal pipe coming from the t-stat which should go down to the dist block. So does that pipe from the t-stat (shown above) just run straight to the bulkhead? Share this post Link to post Share on other sites
C_W 3 1 Cars Posted June 23, 2005 That's how I'd got mine. But you also how a water oultet pointing out of the side of the head nearer to the thermostat which is what I've blocked off. Share this post Link to post Share on other sites
Ryan 99 Posted June 23, 2005 I've got the 16v thermostat if that makes any difference. I'm having the metal pipe going from the rear of the stat housing to the distribution block. One pipe for the heater matrix goes to the side of the stat housing (the one some people block off), and the other goes to the distribution block. The final outlet on the distribution block will go to the bottom of the expansion tank. I've got plenty of bits of hose left, so I'll have to bodge something to repair the hose. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted June 23, 2005 Just use the normal 8v water dist pipe at the bottom of the engine and the heater hose comes off the side, A P2 heater hose is a direct fit, On the stat housing just cut the long metal pipe off and 'Tig' a patch over it, I'm a great beliver that the less hoses and bungs/blanks you have the less chance there is of something spliting Share this post Link to post Share on other sites
Guest SeanT Posted April 24, 2006 My dist hose has given in and Ive found this post, just want to confirm before I go and order one, you suggest a P2 heater hose is a direct fit.....Is that a 205 p2 heater hose??..and are these still available from peugeot? Thanks Just use the normal 8v water dist pipe at the bottom of the engine and the heater hose comes off the side, A P2 heater hose is a direct fit, On the stat housing just cut the long metal pipe off and 'Tig' a patch over it, I'm a great beliver that the less hoses and bungs/blanks you have the less chance there is of something spliting Share this post Link to post Share on other sites
jonnie205 1 Posted April 24, 2006 as mile says a phase 2 hose is a direct fit to the side outlet of stat so you can cut metal pipe off and tig that. A phase 1 hose is a direct fit to the metal pipe that goes to the stat, in whcih case you can blank off the side outlet. It makes no odds which oulet you use or blank off. Share this post Link to post Share on other sites
Phil H 16 Posted April 24, 2006 The hose you need in your picture is no longer available from Peugeot or Citreon...you will have to ring round some dealers, like I had to last week, found one in Newcastle and was £6.50, sent them up a tenner and a jiffy bag and Bob was my Lobster two days later. Share this post Link to post Share on other sites
Ryan 99 Posted April 24, 2006 You need to find a more helpful dealer! The parts guy at mine got one brought down from another dealer up north, gave me a ring when it arrived, and I just had to pick it up. Share this post Link to post Share on other sites
Phil H 16 Posted April 25, 2006 You need to find a more helpful dealer! The parts guy at mine got one brought down from another dealer up north, gave me a ring when it arrived, and I just had to pick it up. He did offer that service, but no other dealers in the chain are near me, so had no option really. Share this post Link to post Share on other sites
Guest SeanT Posted April 26, 2006 Cheers Phil, this is fast becoming a right pain, been off the road for 2 days and no closer to gettting it solved really....Ive just spoke to the local dealer again and he is going to post it on the internal bulletein board but he said its not viewed everyday and wont necessarily come up trumps....Ill have to maybe ring round like you did!... If anyone else has any ideas or a pipe would appreciate the help... Sean He did offer that service, but no other dealers in the chain are near me, so had no option really. Share this post Link to post Share on other sites
