Guest ashnicholls
Fuel Pumps
Guest ashnicholls
Ok cheers,
I think its working now.
As you say it does not turn off, and i think the float levers had stuck as I reconditioned them about 3years ago. Because when I tried again no flooding occured and i think the air was just the system bleeding as that has now stopped.
Does it make a difference if the pump is mounted vertically.
Cheers Ash
mfield
iirc the outlet should be higher than the inlet
Guest ashnicholls
Yes how i have done it, so its right.
They are labeled and i positioned it so the writing was the right way up.
Cheers Ash
