Rob Turbo
Rear Beam Part Numbers
Rob Turbo
I'm gonna attempt a rebuild myself, i'm gonna buy all the usual bearings and seals before i start and hope nothing major is wrong
Is there a kit of bearings or do i just order each one seperately?
Either way does anyone have the part number(s) to save me searching the parts cd?
I've read the guide and i'm fairly confident i can manage, but does anyone have any pointers that would make life easier?
Rob
Theo205
5176 17 Trailing arm shaft
5172 24 Anti roll bar bearing bush
5174 03 Crossmember seal (anti roll bar lever)
5132 49 External bearing
5131 45 Internal bearing
5154 05 Plug
5154 08 Suspension arm seal
5154 09 Cup
5154 10 External seal (suspension arm seal holder)
5153 12 Suspension bar washer
5153 11 Crossmember screw
5153 10 Suspension bar stud
6962 66 Spring washer
6932 38 Hexagonal nut
GOD bless Wurzel :lol:
Wurzel
The anti roll bar bush, suspension bar washer, crossmember screw, suspension bar stud, spring washer and hexagonal nut may all be reuseable if you're lucky/carefull.
They don't cost a lot though in the scheme of things and if you're rebuilding a beam you may as well do it properly, also, there is nothing worse than not having one of the small bits and having to stop the build.
One word of warning though, the smaller items like the washer etc may come in packs of tens or more so check first. I'm sort of lucky in the fact I get through a fair amount of beams and so always use them up or the dealer holds them for me charging me for the amount I need at the time.
Guest woods
Rob
Me and Credowan used Nicks guide to the button, and found it spot on TBH. I have now taken about 5 apart, and am getting quicker each time.
Mine was FUBAR on my car, so i took the drivers side shaft out to inspect, and the bearing was pretty much gone. The shaft itself was fooked, so it was a sure case of re-furb.
I now know the diff between a good shaft and a pooped one.
I would reccomend you remove the rear beam totally to do the job, and also allow for poss replacing the mounts too. (about £10 each i think)
Use only Pug parts mate, cos for the diff in price, it not worth it.
The shafts are only avail from Pug, i believe, and are the most costly part of the build.
Following Nick guide will see you right tbh, me and credowan had no probs. (apart from wacking hell outta trailing arms)
The shafts themselves cannot be moved from the trailing arm without a press, so you will need to aquire a mates press, or a local friendly garage.
Has your car the usual signs of needing a rebuild then mate??
Is also a good time to get under the car and cleanit up, and clean the beam up too.
I will be starting next wkd i expect, and will incl a load of pics. I also have the front to lower on mine too.
Gaz
Rob Turbo
Cheers for the info everyone! Much appriciated :lol:
My beam has started squeaking when i get out of the car (probably while i'm driving but i cant hear it) and its getting worse!
Rob
Wurzel
Rob
Don't confuse that with the rear bake ie handbrake on and the discs/pads creaking.
Rob Turbo
Good point!
I never thought of that, i'll try leaving the handbrake off when i get out and see if it still creaks!
Rob Turbo
Tried it, but it still creaks!
Ah well, worth a try!
Rob
Wurzel
Always a long shot but deffo worth a try.
Never mind, rebuild it is though expect the worse if it's creaking :lol:
Rob Turbo
Thats what i was thinking, after hearing about apparently good beams being fooked inside!
Guest cslcraig
could you let me now on what sort of price for the parts as i need to do mine
Wurzel
That little list will cost around £170 to £180 for both sides :P
Shafts cost the most at £55 plus VAT each.
Rob Turbo
I have a cunning plan for replacing the shafts thanks to woods!! :P
Going to order seals etc from pug, then off to the scrappys at the weekend for a bit of a hunt!!
Rob
Wurzel
You're lucky your scrappy allows you to split the beams and leave the trash! The ones around my way are adamant that if I take a beam and find it's tits, it doesn't get taken back.
If you split any GTi beams, keep hold of the bars and arb lever ends though. That coupled with some of the good tubes (be it from a base model) can easily be made up to a good beam again, just a little more expensive :P
Rob Turbo
I'm mainly going to hunt base model trailing arms, with the shaft, which i can get pressed out by a bloke down the street, also if i find any that have two good nic shafts i'll take the tube too!
If i happen to build up a nice collection of good bits i'll let you know, i'm sure you could do with some extra good bits??
Rob
pj838
Does anyone have the part number (and cost from pug if poss) for the ARB lever arm?
The splines in mine are shagged, thnik I'll need a new ARB as well :rolleyes:
Paul.
5178 10 BAR LEVER LEFT - GTI RALLYE
5178 11 BAR LEVER RIGHT - GTI RALLYE
No idea about how much they'd be from Peugeot but most likely not cheap. :excl:
You'll probably be better trying to find a GTi in a scrapyard & get the one for whatever side you need from there or try a wanted ad on here.
Graham.
pj838
Thanks for the help :) . Stripping down my old suspension and the bar lever can be turned on the ARB by hand, bit of corrosion there lol. A Wanted ad sounds like the way forward :)
pj838
OK I now have 3 good ARB levers. Cleaning them up ready for rebuilding, - can someone identify this part (2 shown), it was attached to the bar lever and is some sort of seal/pad..?
I'm thinking its either:
Paul.
Wurzel
5174 03
It's a daft bit of foam that helps seal the lever to the arm.
What do the splines look like on the ARB? I have no idea about the history of your beam, but if the wrong lever is placed on the wrong end of the bar, the splines don't mate. It feels as if they are trying to but the lever splines are just slipping over the splined end of the bar.
If it's all rusted to feck then so be it, but possibly someone has played with it before and is salvagable.
pj838
thanks nick - the arb is now my new 'handy metal bar' as the splines on one end are badly corroded. I've just bought a decent one inc. levers that I'll use, good job I left one lever on it though, I'll mark up which side is which now ;)
Wurzel
I have to admit that out of the couple of beams I've rebuilt, that is the first I've heard of corroded splines. First time for everything though ;)
Good luck with the rebuild though.
By the way, how much were the end levers or did you get them second hand?
pj838
Here's the two ends
looks a bit dodgy?
Got my parts secondhand, didn't ask for the pug price thought it would be painful...
max0
not sure if thats dead or not but ive got a standard anti roll bar kicking about from a diesel, your well to have it if needed. Its not as fat as the GTI one but its in good condition.
Andy
Wurzel
To me, it looks like the incorrect anti roll bar end has been fitted. I reckon those splines could be cleaned up and a correct end fitted.
