Guest RALLYPUG
Brakes
Guest RALLYPUG
I have a slight judder through the steering wheel under braking thats just started.
Any ideas?
Guest Bigj
Warped discs, worn pads, wheel bearing on the way out (unlikely)
worn discs.
Suggest you take the wheel off and have a gander
Let us know what you find
J
Guest RALLYPUG
front discs and pads fitted by SBC 10k ago.
Will check the bearings
Guest web
Even loose caliper bolts are possible. Don't ask how I know :)
Also just because the discs are just 10k old doesn't mean they can't be warped.
Guest RALLYPUG
How do you check for warped discs?
M3Evo
Wheel off, pointer by the disc, give it a spin.
People seem to forget that leaving your foot on the brake pedal after a hard stop can cause warping!
USE THE HAND-BRAKE!!!
miamistu
I don't think using the handbrake for a hard stop is a very good idea :)
M3Evo
Arf arf! Very funny Zim!
cybernck
check for play in the steering rack as well.
Guest RALLYPUG
Its not the brakes.I can feel a slight vibration all the time through the steering wheel but its worse when braking.
I've checked the tyres and pressures and found nothing.Will get it over the pit at work tomoz and check it.
Just done 1500 miles in the last week or so going to Felixstowe on the m-way and it just got slighty worse on the way back. :)
Any ideas?
j_turnell
Tracking, Wheels unbalanced????
Guest RALLYPUG
Yeah.Will check the underside tomoz and if l find nothing then i'll get the tracking done.
I've hit a few big pot holes recently but didn't notice anything straight away......and a plastic bottle at 95 on the A14 :( but couidn't see any damage.
C_W
Check the wheels aren't flat spotted/buckled.
doogz
I had a similar thing on my previous 205 (not a gti tho), i replaced bearings, calipers, pads, disks but it still did it. I eventually fitted another rack and it cured it.
