pugbliss
Rear Light Casing
pugbliss
after you take the lense off i.e to get to the bulbs how do you get the body casing off???
the reason i ask is that im having a few probs with the bulbs and i think its corosion
and would like to take them out to clean up.
can anyone tell me how to take them out/off
cheers
hd_andy
Are you talking about the bulb holder? If so there is a 10mm nut holding it to the body, access is in the boot
pugbliss
cheers ill have to look but off hand i carnt remember ever seeing 1 there.
Batfink
If I remember rightly its not an easy screw to get to
pacey205
Piece of piss if you ask me. Passenger side peel back the carpet on the side of the boot to get acces to the hole behind, 10mm socket on small extnesion bar, feel socket onto the bolt and then unscrew.
Drivers side is the same except you have to remove the rear washer reservoir.
HTH
Michael
pugbliss
Mmmmmmmmm
ill have a look on wed nesday then??
cheers all
