phil19gti
10k Boost
phil19gti
I read on here a while ago about this stuff and I was wondering if it's worth using it or not?
Halfrauds have got it for sale at £25, but I don't want to spend that amount of money on something that might be useless.
Thanks in advance.
RichA
Personally, I'd buy enough redex to clean out your cylinders, and a can of carb cleaner. Both should come to under a tenner - and, in my opinion, more likely to clean things out properly.
Running redex with your fuel every once in a while is generally considered to be a good way of minimising carbon buildup. Poured directly into the cylinder and left to soak should break up the carbon quite well.
--Rich
Edited by RichA
ultimatepug
ive got a can of 10 k boost i found in my lock up, does any 1 know if it does any good or not? if it does then i'll use it on the 205 :D
adam
Dave
*cough*its-just carb-cleaner-in-a-different-colored-tin*cough*
Guest CB-Dave
I'm not so sure bout that - if you ever shake a can of 10k boost it feels like it's a solid lump inside, carb cleaner never feels like that...
RichA
My Gillette series gel for sensitive skin with soothing aloe feels like it has a solid inside. I'd always likened what comes out of it to rabbit droppings, but I think I've cracked it now.
A bottle of Redex will help clear out the rubbish. The carb cleaner will give a clear-out to the bits that Redex just can't reach. And finally, we have Gillette series gel for sensitive skin with aloe vera to ensure a nice, smooth, clean shaven feel to everything. For better airflow, obviously B).
And still under £15. The left over £10 is most welcome as a personal donation to the 'RichA product testing fund' :D.
--Rich
huxley309
do we also get that saleen s7 for our £15 sheets? :D
Guest CB-Dave
Just remember, if you put too much redex down the pots it will highten the compression and you could quite easily blow a headgasket by doing so.
I'm also *very* skeptical of adding anything to the fuel tank, cos surely it will just get filtered by either the intank prefilter, or the fuel filter before it reaches the injectors... plus, anything you put in the tank essentially dilutes the petrol which means less RON points...
RichA
Redex down the pots, cover the spark plug threads with rag, leave to soak for 20-30 minutes, crank for 20 seconds, then leave for another 20-30 minutes. Obviously, don't throw a load of Redex down the cylinders, refit the sparkies, then fire her up :D.
The amount of Redex you put in your tank is rather unlikely to alter the octane rating of the petrol by any noticeable margin. We're talking 50ml of Redex for 50 litres of fuel, or something along those lines... personally, I'd not bother using it regularly with petrol. I'd just use it down the cylinders every once in a while. The leftovers can go in the fuel tank B).
--Rich
adrian_gti
would i just spray the carb cleaner in the afm with the engine running????
i used 10k boost b4 and only noticed a slight improvment... not £25 worth of improvments tho!
